Larger tank options for the carbureted 250?
Old Jun 9, 2025 | 05:01 PM
raketemensch's Avatar
Default Larger tank options for the carbureted 250?
After almost 4k miles I've developed some real range anxiety, and drained the reserve about a mile from a gas station yesterday.
I really don't want to drop $400 to get an extra 0.7 gallons with the IMS option. It looks like there's a 3.8 for the 300 now, but after watching a few videos it appears to just be for the FI models?
Has anyone tried adapting one to a 250?
Old Jun 9, 2025 | 05:27 PM
hobospeed's Avatar
My understanding is that the Acerbis 3.7 gallon tank for the 90's KLX 250/300 will fit on a carbureted KLX250 with minor modifications. I believe one the of the issues is that you need to mod the choke as the fuel petcock interferes with it. I'm pretty sure I've seen a thread on this forum on the subject.
https://www.acerbis.com/eu/motorspor...-tanks/0001594
Old Jun 9, 2025 | 06:22 PM
GBAUTO's Avatar
I use the Acerbis on my '12. It also replaces the radiator shrouds and comes with additional braces so that it provides some crash protection.
I have the pumper carb on mine, but it's quite easy to use it with the CV.
Here are the installation instructions for reference.
https://www.acerbisusa.com/2008-kawa...01-color-black
Old Jun 9, 2025 | 09:20 PM
Awesome, thank you both. I have a 2012 as well, and am holding off on the pumper carb for the moment. I'll dig around for the installation thread.
GBAUTO, how is the routing with your aftermarket brake lines? This stock line drives me bat****.
Old Jun 12, 2025 | 06:40 AM
RaceGass's Avatar
Here’s a pic of a 09 klx with the Acerbis tank installed. Iirc the bike is owned by a member on here, and it’s not all that difficult to install. Theres a post explaining it on here somewhere.
I saw pics of the newest 3.8 gal IMS tank on a FI klx that’s pre ‘24. Wonder if an aluminum block off plate could be made to run that 3.8 gal tank on a carb klx, I’d like to see the bottom of one of the newest tank. The radiator shrouds don’t line up perfectly, but it bolts on. The ‘24-5 klx rad shrouds go for $213+
Old Jun 16, 2025 | 04:05 PM
LaGrasta's Avatar
I'm using the Clarke for my 2014. Yes, far too expensive IMHO. In doing so I also removed the smog equipment and now when the bike is on its side, no more fuel leaks. That's the best larger fuel tank upgrade feature!
Old Jul 14, 2025 | 01:57 AM
Old Jul 14, 2025 | 11:48 PM
wjstengerjr's Avatar
Default fuel leak
Hello, can you elaborate further about the fuel leak when the bike is on it's side? I noticed the last time I dropped the bike that it piddled some gas onto the ground. How does the smog equipment cause this, some kind of evaporative valve, or something? Also, what kind of oversize tank are you using?
Thanks,
Will
Subseageorge
Apr 2, 2021 11:57 PM
dualindalton
Apr 1, 2021 04:02 PM
dualindalton
Mar 31, 2021 07:47 PM
bmwhd
Aug 27, 2006 04:36 AM
kmarshall
Aug 8, 2006 08:12 AM
