KLX250SF Front Brake Assy on a KLX250S
Just wondering if anyone has done this as the SF has a larger diameter disc due to the smaller wheel size.
Looking at a parts list the following items are different - Rotor - It looks like the SF has a two piece item without a damper; is also thicker on SF. Caliper & mounting bracket - Caliper is also black on the SF Piston, seals & pads It appears both discs bolt up to the hub with four M8x15 bolts but are the spigot size & pitch circle diameter of the bolt pattern the same on both? Any thoughts on whether this would be a worthwhile upgrade or if there are alternatives available to improve braking? |
^ I have edited text with a better explanation for the mod
For what purpose?
Get a braided stainless steel brake hose and you're good to stop. Bill Blue, who does the 351 kits sells them. Or try Galfer.
(Post 471142)
I think upgrading the brake line and brake pads would produce better results than simply swapping the disc and caliper for the SF stock. |
Old thread dredging again - I'm looking to Sumo the KLX and race, it would seem going with the larger SF rotor would give better front braking... wouldn't that be the obvious purpose of the upgrade? That's why Kawi did this on the SF version after all, right?
I'm buying new rotors either way, wouldn't it make sense for street to get the bigger setup? (fwiw, I came across this thread looking for the SF bracket part number) |
Originally Posted by mmmbeefy
(Post 519992)
I'm buying new rotors either way, wouldn't it make sense for street to get the bigger setup? (fwiw, I came across this thread looking for the SF bracket part number) Honestly with the KLX250SF in stock form it is more for looks though. Remember, you need the different carrier unit, I'm betting the caliper is same as the S model except color. They ain't cheap, but if you want the big brake it's worth it. My 650 runs a similar 300mm rotor and it stops really strong even with about 75 lb more weight. I'd love to do one on my 250, have the rotor, but not the carrier. Got it when I got an extra set of hubs for the 650 to make some SM wheels - wanted the road tires and the look when not running dirt/gravel/single track. Then I got the 250. |
I swapped my front rotor with the 300mm unit from the SF. You will need the caliper bracket to line everything up. My braided line fits fine with the larger rotor. I did it to allow single finger braking off road and it does that just fine. I haven't had any issues with the larger rotor smacking any obstacles-it's only 1" larger when measured radially compared to the stocker.
Like I said, same as the KLX650C - 300mm rotor.
2 Attachment(s)
Originally Posted by klx4me
(Post 471070)
| All times are GMT. The time now is 02:20 PM. |
