KLX250 will not idle with choke on
Old Jul 1, 2023 | 02:24 PM
Sini's Avatar
Default KLX250 will not idle with choke on
I have a 2009 KLX 250 that I installed a new carburetor in. When the choke is off, the bike runs exactly as it should. The idle is perfect and it revs and rides great. However when the choke is on and I let it idle, it immediately dies. I can hold the throttle open with the choke on and the bike will rev really high as expected, but as soon as I let the throttle go the rpms drop and the bike dies. This is a brand new carburetor so I don't know if some screw needs to be adjusted? Looking for ideas on what to do.
Old Jul 1, 2023 | 11:11 PM
HemiBob's Avatar
Is this a stock CVK carb or an aftermarket unit?
Old Jul 1, 2023 | 11:15 PM
Sini's Avatar
It is a stock CVK carburetor.
Old Jul 1, 2023 | 11:27 PM
HemiBob's Avatar
Being a new carb, I'll assume that's all fine. If you are at high elevation, I would expect it to not need the choke/enrichment. It's possible you have a restriction somewhere, maybe a clogged air filter or something like that.
Old Jul 2, 2023 | 12:07 AM
If it's rejetted it might be that you don't need the choke except to start. I know my bike will only need choke for about a minute or less in most conditions. Other possibility is that the choke, which is not a real choke but rather an enrichening circuit, the passage might be clogged and need cleaned out... if the carb is used.
pvr02
Ninja 250R
Aug 29, 2019 12:05 AM
frogandtoad
Nov 13, 2014 11:45 PM
CousinLarry
May 10, 2010 04:19 AM
Skilo
Mar 28, 2007 06:16 AM
ntloser
Aug 26, 2006 03:13 PM
