KLX250 09 - Rear Fender Alternatives
Old Sep 1, 2010 | 08:50 PM
Highbeam's Avatar
Not as bright. Much smaller and "under" the rear fender as well. Probably good enough. I feel a little spooked riding at night with it.
Old Sep 1, 2010 | 10:47 PM
spoof's Avatar
That's what I was afraid of..
Old Sep 1, 2010 | 11:35 PM
Highbeam's Avatar
And I have the red one! The smoked must be really dim.
When the brake light is engaged the brightness isn't bad but the tail light isn't too impressive. Looking at the photos it is about half the size of the OEM light too.
I really like the looks and how the edge light is out of the way. Still happy with the change but safety IS compromised.
Old Sep 3, 2010 | 09:53 PM
slippery750's Avatar
I had the smoked Edge too. I did'nt realize how dim the brake was till I was behind a buddy on a DRZ with a smoked Edge. I immediately went to work retrofitting mine. There is a replacement LED board for the Edge available now for about $100. Seems a little steep to me though.
Old Jul 13, 2011 | 07:09 AM
Copperhead16's Avatar
Cliffsta,
Looking at doing a similar cut of my fender to trim off that awful looking lower portion... Can you elaborate on what tool(s) you used (dremel?) and if you removed that portion of the fender first before you trimmed it?
Copperhead
Old Jul 13, 2011 | 08:34 PM
Mesk's Avatar
With the Edge tail light kit, where do you put the electrical terminals since there is no place to hide them with the mod kit?
Old Jul 28, 2011 | 07:30 PM
ahnh666's Avatar
looks like my bolt-on tail light selection is limited to the edge...
should i use the stock blinkers or use a flush mount?
Old Jul 28, 2011 | 07:49 PM
  #28
Malves's Avatar
Use the 12oclocklabs upgrade board for the Edge tail light. It has integrated blinkers and it uses 16 superbright LEDs that are MUCH better than the ones that come stock with the tail light.
Old Jul 28, 2011 | 08:57 PM
  #29
camrs73's Avatar
+1 definitely and the flash pattern when you hit the brakes is the ****. really draws attention.
Old Jul 28, 2011 | 11:00 PM
  #30
Malves's Avatar
Not to mention it makes the bike look even cleaner without "hanging" blinkers. Here's my bike.
https://www.kawasakiforums.com/forum...-21590/page94/
