KLX 250s Help
Old Mar 12, 2018 | 08:49 PM
Mick-F88's Avatar
Default KLX 250s Help
I have the bill Blue 350 kit and I could use someone with experience to help me install it. Do I need to do any adjustment to the piston rings or are they already the correct measurement for the new liner? Any recommendations on new coolant for the bike, or any other tips? I had previously removed the snorkel and installed larger jets. I am located in northeast Mass.
Thanks , Mick
Old Mar 12, 2018 | 10:18 PM
Hi Mick,
Bill usually ships rings with the correct gap, but they should be checked. Do the instructions show the gap, or is this in the manual? I don't recall. You should have a shop/service manual, and if you don't, it's a good idea to find one before this project.
See my sig line for my 351 install and links to some others.
Old Mar 13, 2018 | 06:49 PM
sphen's Avatar
theres a lot you need to get right, and this forum definitely is a wealth of info. err on the side of asking before you do something you're unsure of.
coolant wise - i switched over to engine ice at the suggestion of a member here, and the bike runs noticeably cooler that way.
definitely get the shop manual (pdf available around the web). be sure to stuff rags in the oil gallery, crank opening, etc. dont wanna drop something and have to split the case open to fetch it. keep some tension on the cam chain after you take the cams out. take pictures of the timing marks before you take the cams out.
etc, so forth, and so on.
theres a youtube channel - mr duh factor or something like that - has an in depth install video.
Old Mar 14, 2018 | 11:23 AM
Mick-F88's Avatar
Angry Bill Blue kit
Thanks for that information, I now have the shop manual. I will try and dind that youtube channel fo the install. Nor today tho, got to clear 25 inches of snow from yesterdays storm!
Mick
Old Mar 14, 2018 | 02:10 PM
durielk's Avatar
#1 priorty, get your cam timing right.
#2 Get a torque wrench and use it.
#3 Be sure and add coolant before starting it (don't ask me how I know)
#4 Don't forget the piston clips and installing the rings in the proper rotation.
Old Mar 14, 2018 | 02:11 PM
reinigef's Avatar
Here is the Katsumi 351 engine build video...
Old Mar 14, 2018 | 02:12 PM
reinigef's Avatar
Old Mar 14, 2018 | 10:29 PM
RaceGass's Avatar
Make sure to confirm ring end gaps, take the time to insert them into the bore and manually check them yourself. Never leaved that up to someone else.
While your inside the cyl head check your valve shim sizes. That way when it's time to adjust your valve clearances you already know the measurements and get your shims ahead of time to do the job.
My '09 valve cover gasket shrank, when buttoning up my big bore install I noticed.... Requiring me to delay completion until I received the replacement gasket.
Happy wrenching!
Old Mar 17, 2018 | 02:03 PM
Mick-F88's Avatar
Thanks for all the info, PDF, videos etc. I will be starting this next week as soon as I get my commando off the lift table.
Mick
gthomas17
Sep 30, 2015 06:53 AM
Gteeiguy
Oct 14, 2013 03:23 AM
jpaul310
Aug 10, 2008 10:41 AM
jespo
Feb 1, 2008 02:14 AM
incabiker
Jul 3, 2006 10:56 AM
