klx 250s 351 big bore
none,,,,,,,,
Although an aftermarket muffler helps the 351 reach its fullest potential. There are other mods you can do but I think they only return marginal gains.
351 and FMF Q4,
Dan
351 and FMF Q4,
Dan
so what jets should i get? and does anyone have a idea how much improvement a new exhaust and header would make on top of the 351?
also would i need different jets if i have or do not have the new muffler and header?
Frampton, have you read much of the post history on the 351 install and associated jetting? While it may take awhile to read through this info, if you're fixing to spend this much money and time doing the job, I think you'll find it worth your while. You're asking the most basic questions which are covered many times here already.
Replace the clutch springs before the oem springs let it slip rendering your clutch plates useless. Barnett offers some that work well.
Power increase with the big bore kit quickly shows how the tension of the stock springs are inadequate in the upper gears (slippage)
thanks!
ps: i am at sea level
thanks for your post TNC but i have read alot its just that i have heard different kits and most of them for bikes that have a aftermarket muffler aswell. the main reason for my posting is to learn exactly what jets i can choose and if a new muffler and header will actually help much
thanks!
thanks!
