KL250 aka Super Sherpa
Greetings.
I didn't see a section dedicated solely to this model, so I thought I would post this in the 250 section...Admins can move this if desired. I've been reading up on re-jetting the little one, but there is no mention as to whether there is an airbox modification that goes with it. On most other models, re-jetting means opening the airbox to a certain degree. Any insight? |
Originally Posted by Qwazert
(Post 519277)
Greetings.
Thank you for the reply.
It was the same for my DR650...terribly lean from the factory and required extensive tinkering to get rid of the lean surge. Bought a ProCycle jet/needle kit and it helped immensely but then I broke down and bought a pumper carb the next season. Do you have any links as to where I could buy one of these "performance jet/needle kits" for my little Sherpa? Procycle doesn't stock items for the KL... |
(Post 519290)
It was the same for my DR650...terribly lean from the factory and required extensive tinkering to get rid of the lean surge. Bought a ProCycle jet/needle kit and it helped immensely but then I broke down and bought a pumper carb the next season. Do you have any links as to where I could buy one of these "performance jet/needle kits" for my little Sherpa? Procycle doesn't stock items for the KL... http://www.jetsrus.com/a_jet_kit_dirt/kawasaki_250_KL250_super_sherpa.htm But the cheapest would be to shim the needle, richen the AF screw and possibly drill the slide port a tad bigger. These free mods worked great on both a klx400 and dr650 of mine. |
Thanks....I appreciate the help!
Do you know of any online dealers who sell parts for this model?
I've dealt with BikeBandit before and I had no problems getting parts for my DR or TW...but it's as if the 2006 KL250 doesn't exist! There's lots of listing for KLX's and KLR's and the KL's that I have found only go as far as 2004, then it picks up again at 2009! I can't seem to find OEM parts for this year of KL.... |
Try RonAyers.com.
But they don't list every year, just years where changes were made. So if the 06 hasn't changed from the 04, it might not be listed. |
Thanks...I'll try Ron Ayers!
I saw your posts on advrider and dualsportbc as well.
(Post 519306)
The airbox is unmodified. As to fuel tank, I ordered a black clark tank for a Honda xr650l and mounted that to the bike. Pretty simple actually, need to changed the frame pucks and make a bracket to support the back of the tank. Like I said i'm in your neck of the woods and might be attending the newbie ride next weekend ( depends on whether my counter shaft seals show up in time) I'd be happy to let you see it if you want. I ordered my jets from pjsparts. |
Welcome to the forums. Q :)
