kick starter?
so has anyone else looked into or successfully put a kick starter on their klx? i have an 09 250s and id like to have a kick start as a back up like on my old WR 450. any info?
Finger Mullet did the install once:
https://www.kawasakiforums.com/forum...ead.php?t=9044
Here is another person that did the mod using FM's info:
http://www.cyclepathic.com/klx/klx_KickStarter.htm
Looks like a bit of work, but if you're handy...
well i had an 03 wr in high school, then made it into the real world and realized if i hurt myself i was screwed, so i sold the bike, and blew the money. biggest mistake of my life. live and learn i guess.
Good Lawrd, it's not hard just be methodical and go step by step .... If I did it any fool can
Now learning to throw a 10' cast net .... thats hard....I'm talkin Forrest Gump Shrimpin Hard.
So I've read your walkthru a few gazzilion times Finger Mullet... is it really just as easy as draining the motor, pulling off the clutch cover, and throwing in the gears and the ratchet? How much more is involved? Your walkthru is great but I'm still a nervous nelly about taking apart the motor..
personally I think changing the valve shims requires more thought.....but ya basically drain her...remove covers and clutch....Use Lauren's technique for the clutch in the other thread I would
but my way works.The only tricky part or not really tricky, just not intutive, is putting tension in the kicker so it pops back up after you kick.....otherwise easy.
If you have a service manual, no worries....go for it and post results.
Edited Add: I am no mechanical expert on bikes by any stretch...I can change a water pump or alternator in my truck but thats about it, but with the manual it is really easy on the klx.....sayin.
The next step would be to remove the starter motor, etc... It would be worth it to shed weight depending on what the savings would be. My old school Suzuki SP125 (red DR) had no electric start and I didn't give a rip. Dirt bikes should be kick start only in my book.
My son's CRF150F has a battery and starter motor, etc... Just for the laziness of a push button start and it has been the biggest problem with that bike. I wish the KLX didn't have all the bullcrap electric start mumbo-jumbo. Let us know how the kick start kits work out for you guys and how much you had to pony up for the job.
Good luck.
M
Good luck.
M
