Keihin CVK 34
Old Nov 14, 2020 | 02:37 AM
  #31
Tonebone's Avatar
Got another CVK carb from dpippin, thanks alot, bike starts better, accelerates fine, but has decel popping. 35 pilot installed. Opened pilot screw up from 2.5 to 3 turns without much change. Would a 40 pilot help with a lot of the decel popping? Thanks....tonebone
Old Nov 14, 2020 | 02:41 AM
  #32
Klxster's Avatar
First make sure all exhaust joints are sealed tight and not leaking. This means the attach at the head, and the header-to-midpipe connection.
Make sure air injection system is properly removed and all exposed nipples capped off well.
Once the above has been taken care of, and if decel pops are still present, a #40 pilot jet allows full control of decel fueling - allowing you to tune out decel pops if the above problems are not present.
Old Nov 14, 2020 | 02:46 AM
  #33
Klxster's Avatar
Once everything is working correctly, you are free to choose a mod combo and bump up your power levels.
Old Nov 14, 2020 | 02:53 AM
  #34
Tonebone's Avatar
Klxster.... thanks again for your info. I will check the smog system and exhaust tomorrow. Is the slip on to head pipe just a friction fit. I see no other form of attachment of the two. Thanks
Old Nov 14, 2020 | 02:58 AM
  #35
Tonebone's Avatar
Correction on my previous post . The new carb has a 38 pilot in it now.
Old Nov 14, 2020 | 03:19 AM
  #36
Klxster's Avatar
A #38 @ 3 out should not decel pop if everything else is ok. You likely have one or more of the above issues.
In the meantime, going to 3.5 turns out should make some kind of difference.
Header to head is nuts and studs, collar, and metal gasket.
Header to midpipe (with your FMF slipon) is a metal to metal slip fit with the strong band-clamp / muffler clamp to keep it all leak proof. There should be a thin film of high temp silicone on the slip fit..
There is no sense in running your pilot system overly rich in an attempt to cover up a mechanical flaw. Get the exhaust system right, get the air pump system removed and capped off well, then enjoy..
Old Nov 14, 2020 | 04:50 PM
  #37
Tonebone's Avatar
Removing exhaust and checking condition of seals/ gaskets etc. anyone know if this is a stock head pipe? It’s connected to an FMF Q4. Not sure if it’s a full system or just a slip on. By the way , head pipe to slip on had no clamp or sealant, just friction fit....Thanks
Old Nov 14, 2020 | 05:39 PM
  #38
Ain't stock. Looks like the FMF power bomb or a rip off version.
Old Nov 14, 2020 | 07:37 PM
  #39
Tonebone's Avatar
Well, deleted the emmisions/smog system. Removed and replaced/tightened the exhaust system, and now the bike runs/idles real well. No decel popping at all. I am finally satisfied with how the bike starts, idles and performs. Thanks to everyone on this forum for thier help and suggestions, much appreciated....Tonebone
horror_fan
Dec 16, 2017 12:55 PM
44snot24s
Aug 22, 2014 10:18 PM
wreckster
Feb 11, 2014 08:23 PM
djchan
Dec 17, 2012 06:20 PM
ns503
Oct 13, 2010 11:48 PM
