Just a heads up on rotors
Old Mar 6, 2011 | 10:50 PM
cliffsta's Avatar
Default Just a heads up on rotors
Not sure how many of you 09/10 owners have tried changing your front rotor yet, but if you haven't had it off the bike, I advise you do so before it sits too long. The genius at the factory in Tailand used 20 pounds of red Loktite on the bolts and I only managed to get two of the four out. The other two are going to have to be forcibly removed by someone with real tools (read: Not a home mechanic). So I advise any newer bike owners to break loose that rotor and clean out those bolts. A home job is now going to cost me at least an hour's labor with a shop somewhere.
Old Mar 7, 2011 | 12:24 AM
jxg's Avatar
jxg
you can't just drill the heads off, then tap them out?
Old Mar 7, 2011 | 12:43 AM
wildcard's Avatar
Heat. Either cafeful usage of a propane torch or something more precise like a soldering gun.
Old Mar 7, 2011 | 01:02 AM
+1 on the heat .. Someone on here recently mentioned that the red? loctite liquefies at 200 degrees. A heat gun is probably hot enough.
Good luck
Dan
Old Mar 7, 2011 | 02:32 AM
Feral Donkey's Avatar
Yeah, I've found a whole bunch of fasteners like that. Not only are they put in with gobs of locktite but they're way over-torqued too.
Old Mar 7, 2011 | 12:57 PM
cliffsta's Avatar
Every allen head on this bike has been over-tightened. All the bolts on the calipers for starters. C/S sprocket...
Its so frustrating for a simple DIY job like brakes is now going to become a two-weekend job.
Old Mar 7, 2011 | 01:11 PM
CousinLarry's Avatar
You want to see over-tight - crack your motor open, and try to get off the drive gear, the oil pump screws, the flywheel nut, and the clutch basket.
I swear they contracted Paul Bunyon himself just to tighten those nuts down. Freakin retarded.
Old Mar 7, 2011 | 01:20 PM
leftlane's Avatar
Impact tools are mandatory for working on motorcycles.
Old Mar 7, 2011 | 02:42 PM
yes, had to use impact driver on oil pump screws.
I need to find a flywheel holder to get that flywheel nut off.
Old Mar 8, 2011 | 12:25 AM
sw0ggd0gg's Avatar
All my FREAKING bolts are like that. I was uber pissed.
