Installing oversized tank this weekend
Old Jun 29, 2023 | 07:08 AM
ekim250's Avatar
Default Installing oversized tank this weekend
So I got one of those IMS 3-gallon tanks on Amazon for $269. Just wondering if my 2009 Petcock needs a rebuild kit while I'm at it? I didn't bother to order one, and now I'm in a bit of a time crunch cause we leave on Thursday. Opinions, Thoughts?
Old Jun 29, 2023 | 01:21 PM
bmart's Avatar
I'm not sure that I understand. Is it working? How would your Internet friends know if your petcock was working properly more than you would?
If it is working properly, I'd just run it! Worked fine on my '09 with the big tank.
Old Jun 29, 2023 | 05:56 PM
ekim250's Avatar
Petcock works. But you have to remove it and reinstall / reseal the gasket on the new tank. I'm probably overthinking it. But I'm sure it's overdue for a rebuild.
Old Jul 1, 2023 | 11:10 PM
HemiBob's Avatar
I didn't touch the petcock for my tank swap, just pulled the hoses off the tank. There was enough slack in the fuel lines to pull the tank up and then disconnect them.
Old Jul 3, 2023 | 04:23 AM
ekim250's Avatar
Really easy to install. Helped having a friend to hold tank steady while working on it. Very happy. Range now 150 instead of 100. Not necessary to carry a Rotopax anymore.
Old Jul 3, 2023 | 11:53 AM
Tacoma660's Avatar
Did you have any issues with bolts not lining up on the throttle side? I had to push mine down hard for the bolt to line up
Old Jul 11, 2023 | 06:36 AM
ekim250's Avatar
No. Having a friend help line them up made it easy. Bolts in the back did not line up on the side covers and you're supposed to drill but I skipped that part. No problem.
Dash8
Mar 8, 2016 07:09 PM
markklx250s
Mar 13, 2014 07:30 PM
tb865
Feb 17, 2014 08:25 PM
Lilyboy
Feb 23, 2013 03:02 AM
RaceGass
Jun 19, 2012 07:46 PM
