I need some measurements from someones bike.
Could someone measure the distance from the inside of the swingarm to the outside of the rear rim. I would like the measurement on both sides, they are different(I think). Thanks.
Edit: I will also need to know what number your chain adjusters are in. |
RE: I need some measurements from someones bike.
I measured approximately 23.5 inches from the center of the inside of the swingarm to the outer edge of the rear rim. I have the 13-tooth CS sprocket and my adjusters are at 5.5....What are you up to, making a longer swingarm for drag racing?:eek:
Sorry,I need the side to side measurements. I had my wheels apart and want to make sure that they are centered where they need to be when I true them. The wheel is off centered in the hub and the swingarm is different from side to side and I didn't measure before I took it apart.
From the inside edge of my Right Swing arm to the inside edge of the rotor is 1 3/8" I couldn't find a good place to measure on the left side. Hope that helps. I don't see how you could change it being as the Brake caliper is against the Bearing cap on the inside edge and against the swing arm on the outside edge.
if you want to stop down my house and measure my bike you can i'll be around after 4
ORIGINAL: gerrynolan I don't see how you could change it being as the Brake caliper is against the Bearing cap on the inside edge and against the swing arm on the outside edge. Nate I will call you then and stop over Monday if your going to be around. |
ORIGINAL: 2k1w=no$ ORIGINAL: gerrynolan I don't see how you could change it being as the Brake caliper is against the Bearing cap on the inside edge and against the swing arm on the outside edge. Nate I will call you then and stop over Monday if your going to be around. |
Thanks Gerry. I can't change the relation of the hubs. I swaped rims out and all of my spokes are loose right now. If you tighten one side of the rim to much you can still get the rim perfectly true but the rim will be off center with the center line of the bike. |
| All times are GMT. The time now is 02:18 PM. |
