How hard is it to replace fork seals?
I'd like to do it myself since the repair shops want 100-150 dollars for ONE fork to be done... even with the forks off the bike. That's a rip off in every sense of the word(s).
I hear you need a special tool so does anyone know where to get it? I'm very mechanically inclined so I don't think I would have a problem doing it. |
Here ya go. The special tools you need are a seal driver and a fork oil level tool.
The fork's in the video are not from a klx but you'll get the idea anyway http://www.youtube.com/watch?v=W2G-b66F3es http://www.youtube.com/watch?v=Xoep9...eature=related http://www.youtube.com/watch?v=Xoep9...eature=related |
Thanks for the links, I watched them and decided I'm gonna give it a try. What really sucks is that the Fork Seal Driver at motosport.com is $60!
I use a piece of PVC pipe that I split in half length wise to drive the new seals in. Don't use a metal hammer as it could nick the fork tube.
Ride on Brewster |
PlanetKLX also uses the PVC driver method. Looks like a good plan to me, less likely to scratch your tube. You just saved youself enough money for a new tire/or ?!
Well, I screwed it up. I don't feel like explaining what I did because I'm royally frustrated at the moment. What are my choices for aftermarket front forks that cost under $100,000?
1991-1995 Kawasaki KX 125, 250, 500 forks will bolt in but you will need adapters to use the KLX axle with them.
Some good information here: http://www.planetklx.org/techtips/kx...-forkswap.html Ride on Brewster |
There's no way you F'd those things up so bad that you can't send them out to get rebuilt. Motopro,factory connection,etc etc. Someone can do it.
Turns out I didn't screw up enough to make the forks leak more, and they are sealed and working properly so far. So I thought I would let you all know and thanks for the help!
| All times are GMT. The time now is 03:17 PM. |
