How do you remove the rear shock???
Old 02-24-2013, 11:35 PM
TNC is offline
Originally Posted by RobG
Oh? What's the rate on the SF spring? Moto-Pro wants to use a 5.8 spring when they redo my shock. I don't remember what he said the stock spring was.
Rob
Rob, isn't the stock spring 5.8? You have an S model, off road, correct? I did a 6.0 rear spring on mine.
Old 02-24-2013, 11:42 PM
RobG's Avatar
I dunno... I gathered from talking to him that it was more like a 5.5 or something. Mine's a 2010 if that matters.
Rob
Old 02-25-2013, 12:08 AM
ol'klx-er's Avatar
I'm hoping RockabillSlapMatt would post his weight since he has an SF. I've looked at the parts fiche and all the rear suspension parts, other than the shock/spring, are the same in the S and SF.
Old 02-25-2013, 02:34 AM
JoelThailand's Avatar
This is a heavy duty rear spring for the SF.
It's a 7.4kg/mm & that's what John @ MotoPro recommended for me. I'm 235lbs & wanted a firm ride for fast SuMo road riding!
I think the angle of the linkage is different on the S to the SF which means the spring is harder of the SF, as there is more leverage etc....I think .....that's why I let John do the calculations for me!!
This is the spring John sent me:
Old 02-25-2013, 02:46 AM
ol'klx-er's Avatar
Thanks Joel. The SF spring I have is 23.2 x 8.0, no markings re the rate. I may have missed something in the rear linkage parts but I came up with the rocker and the dogbones being the same for both the S and SF. I'm nowhere near 235# so it might not be worth even going through the work of installing it.
Old 02-25-2013, 03:09 AM
RockabillSlapMatt's Avatar
I fluctuate from 160-175 ish, It feels good to be, I don't bounce around, but it doesn't feel like I'm riding on a sponge either.
Old 02-25-2013, 03:19 AM
ol'klx-er's Avatar
Thanks RockabillSlapMatt, that makes it sound more worthwhile changing that spring. I'm around 175 plus I carry some tools etc all the time.
Old 02-25-2013, 03:41 AM
I've never bottomed out even hitting jumps. Corners great, even handles my 140 gf quite well. I have no complaints
Old 02-25-2013, 04:02 AM
RobG's Avatar
Can somebody confirm the stock rate for the 2009+ bikes? I'm wondering now about the 5.8 that John wants to put on there for me.
Rob
Old 02-25-2013, 07:07 AM
Valkiera's Avatar
John just did mine, when he tested the spring it was between 5.4 and 5.5 (5.47xxx) if you wanted to get specific. That is off a lightly ridden 2012. He did great work, front and rear springs, along with lowering it internally a bit. Feels really solid now, no squishy front when I stop.
Quick Reply: How do you remove the rear shock???
