How to Adjust the KLX250S Speedometer
Old Sep 7, 2007 | 06:45 PM
scion0's Avatar
Default RE: How to Adjust the KLX250S Speedometer
Does anyone use the SpeedoHealer device? I hear it works well, just not sure if the odometer reading is off after the speed adj. is corrected???
Old Sep 7, 2007 | 07:46 PM
mustang's Avatar
The SpeedoHealer only works with electric speedometers. Ours are mechanical.
Old Sep 7, 2007 | 07:53 PM
002197rp's Avatar
NoBrakes,
Super photography and an excellent contribution. Also very complete. Thanks for submitting your work.
Old Jan 2, 2013 | 02:34 AM
PalmStateCrawler's Avatar
Thanks so much for this right up. I knew there had to be a simple way to fix this problem.
** just noticed this thread is over 5 years old!
Old Jan 2, 2013 | 03:46 PM
I just add 5 mph when I ride on all bikes. That's easier. LOL
Old Jan 2, 2013 | 04:39 PM
Mucky_Waters's Avatar
Great write up, but doesn't it give to low a reading now at low speeds?
At least now I know how to set my odometer back now before I put my bike up for sale. (just kidding)
Old Jan 2, 2013 | 05:43 PM
go cytocis's Avatar
Nice write up NoBrakes!
carefully rotate the counter-clockwise. Hold the base of the needle while you do this. It is just plastic that is pressed onto a metal pin, but it is pretty tight. Just don't damage your needle.
Another method I have used is simply to pry the needle off of the metal pin completely using two spoons so that pressure is applied to the needle evenly, and in a controlled manner. That way you reduce the risk of damage to the mechanism...
Old Jan 3, 2013 | 07:14 PM
MikeW's Avatar
ive done this mod on a scooter
I dont remember it having that large aluminum thing all I did was bend the spring somehow and it changed the needle position too
did it 2 times the last time was because the front tire was larger then stock
so just had to fine tune it again
was dead on with my gps too
Old Jan 4, 2013 | 05:26 AM
Fair question, I'll have to check that out
Old Jan 4, 2013 | 03:16 PM
DigiSnapMark's Avatar
Rotating the needle on the post will simply offset the reading, rather than changing the 'scale' of the reading. My speedo is about 10% off, all the way up and down the range.
Let's play a little math. Let's say the reading is 10% low: Indicated = Actual * 0.9
If you rotate the needle such that it adds say, 5mph: Indicated = Actual * 0.9 + 5
Given this, the indicated speed will be correct at one particular speed... a little simple algebra.
Set the Indicated=Actual...
Actual = Actual *0.9 + 5.
Actual(1-0.9) = 5.
Actual = 50mph.
At all speeds away from 50, the indicated speed have a progressively greater error. Given that we are probably most concerned with knowing the speed when in a fairly narrow range of speeds, and trying to avoid a ticket, this sort of error is probably OK.
If you want to have the speed accurate from 0 to 100 (yeah, right), then you need to do a proportional correction to the speedo, which might well involve changing the spring tension.
