To Grind or To Drill - That is the Question
Old Mar 28, 2007 | 03:07 PM
cwgoff's Avatar
Default To Grind or To Drill - That is the Question
Alright ladies, I will be installing my new Tusk Raptor bars in the next few days. In planning for that, I need to decide if I am going to drill the bars to accept the nubs on the kill switch perch and headlight switch perch.
When I installed my last set of bars, I decided to drill, and it worked out pretty well. I hate doing it though, because I am always paranoid that I am going to put the hole in the wrong place since, by definition, you have tomark the locationbefore you really have the switch seated.
Anyway, I know some folks grind the nub off of the perches. For those of you that have done this, do you get much movement of your controls? I know this is one of those "personal choice" deals, but I am just looking for some subjective input.
Thanks.
Old Mar 28, 2007 | 03:13 PM
double d6's Avatar
Default RE: To Grind or To Drill - That is the Question
I ground mine off with a Dremmel type tool.
I have everything tightened up just enough that if I or should I say...WHEN I fall, they will be able to shift and slide RATHER than snap off and break. I do this with all my handlebar attatchments except my hand guards.
Dave
Old Mar 28, 2007 | 03:34 PM
tbav8or's Avatar
I ground mine off no movement problems so far.
Old Mar 28, 2007 | 03:48 PM
motoguy128's Avatar
I ground mine, and I have a little movement. I think I willneed to put some silicone under there to hold them in place. It's not bad enough to matter. I haven't had any issues with hte throttle side, but I've had some rotation with the left controls. It doesn;t move while riding, but after a few rides it does slip a little.
Old Mar 28, 2007 | 04:20 PM
i cut mine off..... you could put a thin piece of rubber between the plastic and the barsto stop movement.
Old Mar 28, 2007 | 04:57 PM
Kawi Wawi's Avatar
Definitely grind. Drilling the bars would probably weaken them.
Old Mar 28, 2007 | 05:02 PM
cwgoff's Avatar
Well, it's looks like grinding is leading by 5-0. I guess I'll be doing me a little grindin'.
I like Eric's idea to use a thin piece of rubber underneath to prevent any movement. I will probably steel a balloon from my kids and wrap a layer under each control.
Thanks for the input gents.
Old Mar 28, 2007 | 05:15 PM
neilaction's Avatar
ORIGINAL: cwgoff
I went the grind and wrapped a layer of electrical tape to obtain a snug fit.
Old Mar 28, 2007 | 05:32 PM
ORIGINAL: double d6
Dave
Exactly what Dave said. I haven't done this to my bike yet, but did it on the wife's bike and the other 225 in the stable. It was when I installed the heated grips on both of those bikes, and had to move everything, I just took the dremmel and their gone. No problems so far.
Old Mar 28, 2007 | 05:35 PM
ORIGINAL: cwgoff
Well I don't know about a balloon, but a piece of inner tube works great. "I'm sorry honey I don't know why your bicycle tire is flat, daddy has to go now."
