Front Wheel Removal Not Going Well
Harbor Freight carries a good low cost torque wrench which is fine for the needs of the average rider. Get a couple coupons from bike or car magazines and buy them for $11.99 each. Money well spent. Car Craft was going to do a shoot out of torque wrenches, but the fact was the cheap tool they might have suspected of being not so good turned out to be very accurate. They did find if you don't back the tool off to minimum setting it can damage the mechanism (spring, and all can have that happen), good tools.
Do that and you won't have the same thing happen again.
spray the cable mount with WD40 or PB Blaster to get it to break loose. I believe the inner cable is inserted from the top so it will not come out when the drive is loosened and cable removed.
firstninjabike
May 21, 2007 06:42 PM
Wannabe250
Mar 30, 2006 05:26 PM
