-   -   Fork Seal Quick Fix (https://www.kawasakiforums.com/forum/klx-250s-71/fork-seal-quick-fix-35774/)
go cytocis Jun 7, 2011 02:45 PM
Fork Seal Quick Fix
On returning from a weekend in the woods on my SF, I noticed significant amounts of fork oil running down the right fork tube. I initially ascribed this to a combination of Thai build quality and the submerged stump I hit while ploughing through a bog. In any respect I was dreading the hours of ‘zen’ it was going to take to replace what I thought was a blown seal.
On Monday while chatting with a colleague, I was informed of a simple repair many of you may already know of, but even if it saves one unnecessary fork seal replacement, this post will have served its purpose.
I was told that the problem may not be a blown seal, but that dirt may have worked past the seal and become trapped between the seal and the fork tub; remove this dirt with a piece of 35 mm film and the leak should disappear. Having no film, I used a plastic collar-stay instead. I slipped it past the seal and worked it around the fork tube. I was surprised how much crap came out of there. After several passes, the collar-stay came out clean and I went for a test ride.
I can report that the fix worked, and I’d encourage anyone else with a leaking fork seal to try this simple technique first before embarking on a seal replacement job.
EMS_0525 Jun 7, 2011 03:02 PM
I have done that too, you can use a milk bottle, i cut it up to make it look like a hook so i can push it up and in then pull it back out hopefully with the dirt.
Highbeam Jun 7, 2011 06:14 PM
Or did you just run out of oil?
Did you replace the lost oil? I have heard a business card works too. Funny how 35mm film has become so obsolete.
dan888 Jun 7, 2011 09:34 PM
You're right it is a fairly well known, but I guarantee that someone will read this post that didn't already know the trick. Well worth the post. Glad it was a simple fix for you.
Dan
