Fork and SAE2´5?
Old 03-05-2012, 08:49 PM
jeffward's Avatar
Old 03-06-2012, 11:02 AM
grahamgower's Avatar
TNC, According to MOTO PRO web site, the stock spring is 5.5 and recomended is 5.8 for my weight -187 Lbs. The workshop manual tells me nothing...
I checked my Static sag which is 32mm, This seems high. { Bike sagging under own weight }.
The race sag is only at 63 mm, This seems low. { Me and kit on the pegs } My impression is that the stock spring is way too soft innitially and a bit stiff with me on the bike and on trails. Gives a harsh ride, especially over rocks n roots.
Makes no sence to buy another spring with the standard 5.8?
Any suggestions?
Old 03-06-2012, 12:00 PM
Old 03-06-2012, 03:41 PM
jeffward's Avatar
Unlike the fork springs, the shock absorber spring is the possibility of multiple brands: Eibach, DSP, KYB, Moto-Pro, etc. No problems with that.
They are compatible with KX250 springs fitted with KYB, so there is a large market.
Definitely put springs suitable for the weight of each rider is important, but I would like to make a clarification:
When I installed the stiffer springs (fork as in shock) expected a firmer suspension. While it is true that hardened a little, in my opinion was not enough.
Really where I have noticed difference is installing the fork hydraulic valve system quality, as RaceTech or Moto-Pro.
In the shock I have only 5'8kgm spring and it still seems insufficient (weight 185lb). As you can install a GoldValve as the fork to prevent this excess subsidence, lacking in progressivity, as recommended by TNC.
Old 03-07-2012, 01:05 PM
Diverse Spring Company that manfactures DSP had this to say.. Thanks for your interest in Diverse Spring. Our F6161265XX series shock springs will work on your KLX250S. I would recommend a 6.0 or 6.2 kg/mm shock spring. If the stock spring is just a little too soft, go with the 6.0, but if it is way too soft I would go with the 6.2 kg/mm.
So which is it, 6.0 or 6.2 for my weight? 187 Lbs/ 85 Kg
Old 03-07-2012, 04:32 PM
jeffward's Avatar
Tough choice.
I am sure with either an excellent compromise reached after completion of preload to adjust the SAG.
Seeing how soft is my 5'8kg I would go for the 6'2kgm. Especially if you do not plan to install GoldValves.
Old 03-07-2012, 06:27 PM
TNC is offline
I have an Eibach 6.0 spring...up from the OEM 5.8...on my '06 model. I weigh 190 pounds nekkid and carry a large Camelback, some tools, and other gear on the bike...quite a few pounds actually on my bigger epic rides. I think a 6.2 would be too heavy for me. I do have Race Tech revalving. Jeff, I think my revalve softened up my rear suspension to where I needed the 6.0. Before that the 5.8 felt just fine. And I guess we can't even compare revalves, as you know when you and I talked on a PM about revalving, my revalve may be noticeably different than yours by my riding needs and preferece.
  #28
Old 03-08-2012, 11:48 AM
OK guys, I am going to pull the trigger on the 6.0. I will report back after I fit and ride it.
Thanks a lot for the input.
  #29
Old 03-08-2012, 08:05 PM
jeffward's Avatar
Yes, I think the 6'0kg is a safe option.
TNC that you say is very interesting. I'll remember that when you install the GoldValve in the rear suspension. I'm wishing for it but the birth of a daughter being delayed. I'm going to be a father within a month!
I wait a bit then.
  #30
Old 03-09-2012, 10:53 AM
[birth of a daughter being delayed. I'm going to be a father within a month!
I wait a bit then.[/QUOTE]
Congratulations Jeff. Well done.
Feral Donkey
03-21-2010 03:08 PM
Psyche
11-06-2009 01:40 AM
56cbr600rr
04-12-2008 02:48 PM
korax123
Ninja 250R
11-04-2007 02:28 PM
eztalking
08-27-2005 07:17 AM
Quick Reply: Fork and SAE2´5?
