-   -   FMF Q4 question (https://www.kawasakiforums.com/forum/klx-250s-71/fmf-q4-question-39686/)
explorer21 Feb 7, 2013 11:18 PM
FMF Q4 question
If I only install the FMF Q4 slip-on do you think I still need to rejet? Do you think I should install the Powerbomb? I just do some casual trail riding and more street.
Brieninsac Feb 7, 2013 11:42 PM
You shouldn't need to rejet with just the slip-on.
RockabillSlapMatt Feb 7, 2013 11:46 PM
Jetting will prove to add the performance, not the pipe, the pipe lets more air flow, which means lean condition in motor, it is already lean from the factory. It is best to rejet :cool:
2veedubs Feb 8, 2013 12:19 AM
True you don't need too, but you should. Stock EPA jetting needs to go, a dynojet kit will help even a totally stock bike. At a minimum remove the plug on your fuel screw and back it out half a turn. Enjoy your upgrades!
linkin5 Feb 8, 2013 06:28 AM
The product insert that came with mine new (Powercore4) clearly said no rejet was necessary. These bikes are stranguled by the stock exhaust and all afr's on completely stock bikes I've seen were actually a bit rich so I believe you are safe without a rejet. I did my powercore4 1st and it added some much needed pep as stock the bike was a total dog and with it, showed signs of life. I then did the dyno jet it as I wanted to do a good ac and airbox mods. Really I didn't notice as big of a jump with the jets and the ac, and box mods as I did with the pipe alone. I then added a powerbomb and it was another small improvment and I no longer think it's a dog.
ol'klx-er Feb 8, 2013 04:59 PM
I forget where I read it but the '07 and older came a bit rich from the factory; the '09 and up come quite lean. I'd expect to have to rejet a '09 & up if installing a freer flowing exhaust.
Brieninsac Feb 8, 2013 05:30 PM
I didn't have to rejet when I put just my Q4 on. But as soon as replaced the snorkel and air filter I did.
explorer21 Feb 8, 2013 10:56 PM
Thanks for all the responses. I am new to this with my 2012 KLX250. I would like a little more power without making too much noise and added upkeep. Brieninsac and linkin5 do you recommend I go with the Powerbomb. If so, I would assume I need to rejet if I go with both Q4 and Powerbomb? Do you recommend the KDX snorkel and what type of gains would it bring? Thanks for helping this newbie!
ahnh666 Feb 9, 2013 03:35 PM
you should still adjust your air/fuel by drilling out the cap to reveal the screw....
Pogiboy Feb 9, 2013 03:50 PM
Since u don't like loud, I have the q4 and its still loud, why not try 13t front sprocket change. Better response than a pipe alone. A lot cheaper too . Just right for occasional trails and highway
