Extended clutch cable
Old 10-18-2012, 08:43 PM
525polaris10's Avatar
Default Extended clutch cable
I have been through many pairs of bars busting my ***. Wanted to try fat bars. I got a riser adapter and when it was all said and done my clutch cable was too tight n barley long enough. I called up motion pro and had them make me an oem cable 2in longer than stock. Everything is the exact same(bends and heat shields) and was an easy replacement. Motion pro does excellent work and they are great people. The price was super reasonable as well. Shipping was also pretty fast bein they had to make the cable and then ship it. I would highly recommend them if anyone would like to run risers and higher bars.
Old 10-18-2012, 11:37 PM
Rosed's Avatar
Good to hear as I just changed to a higher bar and managed to reroute the clutch, a little snug but works. But I wasn't so lucky with the throttle cables, right now they are routed outside the forks, but I will be ordering all new cables from motion pro.
Old 10-19-2012, 01:51 AM
GaryC's Avatar
You could have used the Kawasaki KLX300 cable which is much cheaper, and factory length is 2" longer than KLX250s.
2" longer clutch cable (#54011-0009)
Old 10-19-2012, 02:04 AM
Rosed's Avatar
Does the same apply for the throttle?
Old 10-19-2012, 03:33 AM
Malves's Avatar
+1 Can't beat $10
Old 10-19-2012, 04:02 AM
Good stuff. Thanks Gary. Added to: https://www.kawasakiforums.com/forum...q-links-30733/
Old 10-19-2012, 09:39 AM
griffo1962's Avatar
I used a random one I found in my collection, think it was from a KLR250, now using one from a KLR650 ('08 model) that is a about 4" longer.
still looking for throttle ones......
Old 10-19-2012, 01:23 PM
Jeez guys, stop bein cheap and support the industry. Call up motion pro and get him some business! He will make whatever cable you need.
Old 10-19-2012, 01:51 PM
drm's Avatar
drm
drm is offline
all for that but when you find NOS parts for cheap, then why not. I like motionpro. Although nice, some of it is pricey and many things are made overseas as well.
Old 10-19-2012, 04:47 PM
Malves's Avatar
The industry won´t pay my bills. Even if I support them.
Quick Reply: Extended clutch cable
