-   -   Exhaust for KLX250SF with EFI (https://www.kawasakiforums.com/forum/klx-250s-71/exhaust-klx250sf-efi-31996/)
skybluestu Mar 27, 2010 02:51 AM
Hi,
I will soon purchase a Kawasaki D-Tracker (KLX250SF) but here in Thailand they have fuel injection and I was wondering if the slip ons that are suitable for the KLX250SF with carb would also fit the bike with FI? Has anyone in Europe or Asia fitted a slip on designed for a carb bike to a KLX250 with FI without any problems?
I know very little about bikes but read that the O2 sensor might be a problem, that sound right?
Thanks in advance
SBS
Erekose Mar 27, 2010 06:19 AM
They will fit you bike, you'll just have to drill them to install the lamda sensor in.I live in Greece and have the full megabomb+Q4 FMF system I did that and the bike runs fine.You could also buy the Arrow or LeoVince muffler which is already suited with the adaptor.
slippery750 Mar 27, 2010 06:26 AM
Whats wrong with the EFI? Can't you program or remap the computer for the upgrades?
athelstan Mar 27, 2010 08:50 AM
I've also got an EFI model and have just noticed this listing on Ebay. Would this have any effect or is it just another scam?
http://tinyurl.com/yavpqdh
tremor38 Mar 27, 2010 01:46 PM
I have no experience with replacing the inlet temp sensor with resistors, but it doesn't give me a 'warn and fuzzy feeling' bypassing a sensor that helps the EFI function properly. The sensor the listed product bypasses is key in compensating for altitude and OAT changes so I don't think that's a good idea.
Two Bros makes a 'Juice Box' controller for the EFI KLX that allows you to richen-up the curve once you've uplugged and added a decent exhaust.
LearjetMinako Mar 27, 2010 01:53 PM
Its a scam. One of my buddies tried one on his Alero. Before installing, the ECU read the IAT at 70*F. After the install, the ECU was reading the IAT at 100*F. So the resistor was tricking the ECU into thinking that the intake air was hotter than it actually was. Thus lean out the fuel trim
slippery750 Mar 27, 2010 04:23 PM
They sell the same thing for vehicles. Its supposed to make it think its getting cooler air to optimise the timing for that cooler air.
athelstan Mar 27, 2010 10:43 PM
I'm sorry, I put up the wrong link. This one is for a new ECU and regulator.
http://tinyurl.com/y945fpw
"IT WILL UNLOCK THE POWER THAT THE STANDARD FUEL INJECTED BIKE SHOULD OF BEEN LIKE BEFORE IT WAS RESTRICTED"
I wasn't aware that it was restricted in the first place.
skybluestu Mar 28, 2010 12:26 AM
Don't bother buying that thing, too expensive. Here are the instructions to allow the bike to rev freely in all gears, stock bikes are restricted in 4-6 so the bikes can meet the strict emmission tests.
Here's a link to how to derestrict the bike yourself or have someone do it for you if your not comfortable doing it yourself.
http://www.thaivisa.com/forum/Klx250...r-t244179.html
athelstan Mar 28, 2010 08:30 AM
Thanks for that skybluestu - you're a star!
