-   -   "Do not install KDX 200 snorkle" (https://www.kawasakiforums.com/forum/klx-250s-71/do-not-install-kdx-200-snorkle-37896/)
Websurfing101 May 3, 2012 08:04 PM
Mike from Dynojet says that I should not install the KDX 200 snorkel. Any thoughts on that?
Brieninsac May 3, 2012 08:09 PM
People have been running without lids for a long time. I don't see how a larger snorkel would be bad.
Websurfing101 May 3, 2012 08:13 PM
+1 Will try both ways since I already forked over $30 bucks...
Websurfing101 May 3, 2012 08:17 PM
Brien, I believe you are running a 124 main jet? How do you like it? What are some of the characteristics of how the bike handles with that set up? Mike from Dynojet thinks I need to back down the main jet size also.
Brieninsac May 3, 2012 08:33 PM
I'm using a 128 main jet with my mods below. Other then some minor adjustments to the mixture screw I'm very pleased with the performance.
Websurfing101 May 3, 2012 08:40 PM
I have the 128 main in right now and I am not impressed with the take off. I want the front wheel to come off the ground a little bit better. The mid and high is where it shines. I want the power to feel like that from low, mid and high speeds. Thinking about dropping down to 124 main as suggested by Mike at Dynojet to see where I am at....
rgoers May 3, 2012 08:54 PM
Originally Posted by Websurfing101 (Post 472133)
Mike from Dynojet says that I should not install the KDX 200 snorkle. Any thoughts on that?
I would ask Mike if I were you. Maybe it is because of the Uni Filter...???
Websurfing101 May 3, 2012 09:10 PM
I wish I had a dyno machine at the house. I could try all the combos to see what works best. Too much guess work.
ahnh666 May 3, 2012 09:45 PM
i ran open box and no snorkel with the uni filter....but, after adding the k&n, i added the kdx snorkel...
Websurfing101 May 3, 2012 09:59 PM
It seems that the KDX snorkle would be about the same size as taking the stock snorkle out of the airbox. In theory, same size opening..............
