DG vs FMF Exhaust Upgrade
Old Apr 4, 2018 | 03:04 PM
KawasakiKid's Avatar
Default DG vs FMF Exhaust Upgrade
Hey everyone, I currently have a 2009 KLX 250s and I am looking to upgrade the exhaust. I am torn between the DG and the FMF slip on. Can someone tell me what sets these apart or which one is a better value? Thanks!
Old Apr 4, 2018 | 04:25 PM
RaceGass's Avatar
The fmf would probably resell for more if you choose to do so. Dg looks good , but I see more fmf exhausts . out there. Dg was a company back in the 80’s that’s making the same stuff.
Old Apr 4, 2018 | 05:28 PM
Klxster's Avatar
DG's only bolt onto the stock header.
FMF's will do the stock header and all performance headers.
Old Apr 4, 2018 | 10:16 PM
Dragon351's Avatar
Being totally new to motorbikes, I don't know if the FMF Q4 I have is a slip on, or not. I think it is, but whatever...
my cautionary tale is this... check fitment of whatever you get against the KLX250s airbox. Mine arrived from the previous owner with a large hole melted in it from the tight fit right up against the muffler.
Also, the right rear turn signal is significantly blackened by it's proximity to the FMF's exhale. Others have had this problem, as well.
Old Apr 5, 2018 | 03:53 AM
Klxster's Avatar
Yes, the FMF slipons, and some others, can melt your turn signal. This is an unforgivable failure of design that we must live with. Once my bike was fueled correctly, the turn signal melting stopped. Proper AFR lowers exhaust gas temps.
Melting the airbox is faulty installation and/or failure to tweak the clearance during install.
Old Apr 5, 2018 | 04:29 AM
Dragon351's Avatar
Correct. My turn signal isn’t melted, just lightly smoked
Old Apr 5, 2018 | 04:44 AM
Werloc's Avatar
A slipon only won’t improve performance. The benefit is it’s lightweight. Your exhaust performance gains are with the header pipe. FYI incase your looking for extra hp.
Old Apr 5, 2018 | 01:55 PM
Right now I’m mainly after a better sound and a cheap price. I’m not really looking to spend a whole lot of money with a full exhaust system.
donA
Aug 12, 2017 03:51 AM
Zeenvor33
Sep 11, 2012 12:49 AM
frankb
Jan 18, 2010 05:14 PM
Dubl-A
Jun 26, 2009 11:19 PM
SherpaDude
May 1, 2008 10:48 PM
