Deacceleration popping
For what it's worth, here's a quote from a Mikuni Tuning Manual:
BACKFIRING IN EXHAUST SYSTEM
when the throttle is
closed, especially noticeable from high rpm, is not
caused by lean mixtures, although lean mixtures can
contribute to its intensity. This is a normal condition
when using high performance exhaust systems.
would it be the same idea with stock? only it is louder and more noticeable with aftermarket systems? cause i have my stock one drilled out and you can def hear it when you let off the gas and let it slow itself down
ORIGINAL: mooredan
[align=left]BACKFIRING IN EXHAUST SYSTEM when the throttle is[/align][align=left]closed, especially noticeable from high rpm, is not[/align][align=left]caused by lean mixtures, although lean mixtures can[/align][align=left]contribute to its intensity. This is a normal condition[/align]when using high performance exhaust systems.
I was kinda worried about the decel pop from my bike until I heard the the decel noise from divodaves bike. Now his bike is loud, it sounds like a machine gun.
I always thought that the popping will always be there, you just hear it on performance exhausts due to the straight through design vs. all the baffels and what not on the stock exhaust that eliminate it. I could be wrong though.
ORIGINAL: 2k1w=no$
Wish I had said it...
"It's a friggen motorcycle, it's not supposed to be comfortable, quiet or safe. The windnoise is supposed to hurt your ears, the seat should be hard and riding it should make you sh*t your pants every now and then. Suck it up". -- Scary Gary Mc
"The slowest component of most motorcycles is the rider". -- P. Bonner
