DANGER Will Robinson DANGER
Old Feb 7, 2006 | 01:35 AM
a16tony's Avatar
Default DANGER Will Robinson DANGER
I absolutely hate being the guinea pig.[:@] Rear tank is a no go. Rolled 'er outside to clean, and it wasn't a good thing.
These are bent mounting tabs.
Paint flaking from stress, loose muffler bolt.
And last, but most frustraiting....
I think the weight warning in quite an important issue. I believe that gas weighs 7lb a gallon. 1.6 gallons and the tank are less than 15 lbs. Be carefull what you put back there.
Old Feb 7, 2006 | 02:15 AM
mrphone's Avatar
Default RE: DANGER Will Robinson DANGER
Man that sucks! Was it damaged just from riding, or did you wipe out?
Old Feb 7, 2006 | 03:30 AM
a16tony's Avatar
ORIGINAL: mrphone
From the aux tank I mounted.
Old Feb 7, 2006 | 08:10 AM
scat's Avatar
Oh man that relley sucks
Old Feb 7, 2006 | 10:25 AM
MaverickAus's Avatar
ORIGINAL: a16tony
If you were riding on a smooth road with no bumps at all the weight may not be a factor, however as soon as you accelerate the fuel and container vertically i.e. bumps, jumps etc the G forces come into play. Landing from a jump you may be stressing the rack to 2 - 5 G's therefore increasing the mass (weight) many times.
Sorry to see you broke your bike though, years ago I broke the rear sub frame on my GPz550 I had an engineering shop weld it up for me and strengthen it.
Cheers
Garry
Old Feb 7, 2006 | 03:04 PM
Gravy Train's Avatar
OOOcchhhh!!! That looks bad. However, if I know anything about reading your forums. You have the knowledge,,, you have the skills,,, you have the tools,,,,, you can re-build her!!!! Good luck!! Let us know how it turns out...
Old Feb 7, 2006 | 03:09 PM
a16tony's Avatar
I welded the frame and added some support to the battery side and the rack support bracket.
Old Feb 7, 2006 | 05:47 PM
bmwhd's Avatar
Damn! That sucks! I'll keep my Pelican but watch what I put in it. So much for that idea. Let us pray the IMS solution holds up.
Old Feb 7, 2006 | 05:53 PM
a16tony's Avatar
ORIGINAL: bmwhd
gimme one more gallon ...just one.
Old Sep 21, 2007 | 06:21 PM
zapitbullseye's Avatar
What an interesting way to use old ammo cans. Once you get the back end reinforced, it probably won't be a problem. I wonder what it would look like with the whole bike painted olive drab? Force recon anyone? I wish these bikes had some kind of compartment built in (besides the tiny fanny pack).
