Cranks but...
I have long since done away with letting my bike run out of gas before putting it up. I've even gone two weeks without running and I never have a problem starting it anymore.
The best way I've found is to push the starter button BEFORE pulling out the choke. Let the starter run for 2-3 seconds AND THEN bring the choke out slowly. Mine always starts when I get the choke about 3/4 of the way out. Once it starts, I pull the choke all the way out and let it warm up for a couple of minutes before pushing the choke back in.
I know everyone has their own way but this really works for me. I had all kinds of problems starting my bike when I first got it. Now it seems to be perfect. Of course, I don't know how much all the mods have affected the starting. It could be the jetting and opened up airway.
Just my $0.02!
Oh yeah, I will drain the bike before putting it up for the winter. The gas we get these days is so bad, I know it will gum up the carb pretty quick. My son's dirtbike sat for about a month this summer and then I started having problems with the idle. I took the carb apart this past weekend and guess what?... the bottom of the bowl was covered in varnish. I couldn't believe it. The gas was only a month old. I cleaned all the jets out and now it runs fine.
BTW, I was over at the airport today and they sell regular gas for some old airplanes that don't use 100LL. The gas comes without ethanol. I might start buying my gas at the airport from now on.
Just my $0.02!
Okay I deserve some grief Brian but...
So I drained the bowl and it fired up but only with full choke - I let the bike warm up (this is Arizona so...) and the bike will not idle - just dies. Que pasa? Bad gas? It has been sitting for a while.
I do 2 things that work everytime.
1st - Slowly pull the choke out while pushing the starter button. Should fire up.
2nd - If it doesn't fire up after that, Grab front brake and nose dive it a couple of times. ( compress front shock, let up and repeat) Then repeat the first step.
This works EVERYTIME for me!!! Weird huh??
reset the idle ****- bad gas will still burn just takes a little more- crank it out once you have it running with the choke. I adjust mine all the time because of old or bad gas stations, sometime the lawn mower gas is involved
I would guess the carb needs to be taken apart and dunked in cleaner. sounds like a plugged passage or jet.
Just my $0.02!
Just my $0.02!
In a non-broke-back way, of course.
