connecting rod:where to buy
Old Apr 2, 2009 | 05:16 PM
mauro's Avatar
Default connecting rod:where to buy
Hello,
i'm Mauro from Brescia,Italia.
Very probably i must change my KLX 340 connecting rod.
OEM parts give con rod with crankshaft.
Can you tell me where i can find a con rod kit for my bike?
Thanks
Mauro
Old Apr 2, 2009 | 05:56 PM
Xplosivo1's Avatar
Old Apr 2, 2009 | 08:55 PM
SPKGO's Avatar
oh that might be a hard one. id try to get a hold of kawi about that. I think they might only sell the rod w/crank, atleast like you said thats what oem parts dealer lists. Probably they balance the crank with the connecting rod. so no two are exactly the same due to irregularities in manufacturing. id say it probably isn't to easily interchangable. But I'm no expert
Old Apr 2, 2009 | 09:09 PM
Hey Mauro welcome to the forums. These guys know what they are talking about, I'm sure you will find the answer here.
Old Apr 2, 2009 | 10:03 PM
Brewster's Avatar
I've only heard of changing the crank and rod assembly, never just the rod.
Good luck
Ride on
Brewster
Old Apr 3, 2009 | 12:22 AM
tremor38's Avatar
It has been done, but I don't know where the rod was sourced from. This involved pressing the cranshaft pin out, then back in because the rod is one solid peice. It may come down to taking all the measurements, including weight, then seeing if you can find something close.
Old Apr 5, 2009 | 07:02 AM
lonnie_vining's Avatar
Default con rod
Originally Posted by mauro
Hello,
Thanks
Mauro
Seems like there was a rebuild company using a Honda rod that closely matched the 107mm length of the unobtainable Kawa one. I suppose a slight length difference is made up by a varience in spacers or gaskets between case and cylinder.
Old Apr 5, 2009 | 07:19 AM
neilaction's Avatar
Maybe try Four Stroke Works.
I wouldn't be surprised if Larry could steer you in the right direction.
From memory they did a stroked KLX300.
Old Apr 13, 2009 | 01:37 PM
mauro's Avatar
Thanks to all for your anwers.I have bought an used crankshaft on E-bay.
I hope is good.
When i understand how to do,i'll put the photos of my KLX 340,plastics KX,CRF 47 forks and rear shock Ohlins.
Mauro
shark`y
May 31, 2013 08:56 PM
BFrail
KLX300R
Aug 24, 2009 09:19 PM
BFrail
Aug 23, 2009 12:13 AM
mauro
KLX300R
Apr 2, 2009 03:51 PM
lonnie_vining
Feb 4, 2009 07:06 PM
