complete engine gasket kit where to buy.
Looking around for a complete engine gasket kit, found one for a 09-10 klx250s, but I would feel better finding one specifically for my "07". Anybody know where one can be bought?
Hate to do it piece by piece. Thanks , Dan |
Any thoughts on whether or not the 09 and up gaskets would be the same? I'm thinking they are the same, but I'm not willing to risk almost $200 on the wrong kit.
Looking at the parts fiche from bikebandit, gasket part numbers are appearing to be the same between the '07 and '09. Didn't check them all but here are links to the ones that I did check out. 2007 Kawasaki KLX250S KLX250H Parts, 2007 Kawasaki KLX250S KLX250H OEM Parts - BikeBandit.com
2009 Kawasaki KLX250S KLX250T Parts, 2009 Kawasaki KLX250S KLX250T OEM Parts - BikeBandit.com Not sure if it would be cheaper to order oem gaskets from a parts store, but considering a couple wouldn't work from the complete kit due to your 351 kit, it might be. |
What are you up to Dan?
"Talk to us goose" :)
Thanks NDKLX I am hoping that I don't have to go through the whole fische and cross ref all the numbers. I am pretty sure it's all the same. I'm told that the whole gasket kit should contain all the gaskets and seals. I am going to try and contact the seller of the "09" set and see if they can confirm the fit on the "06"-"07"
Scott, Deej, You don't want to know ........... https://www.kawasakiforums.com/forum...78/#post486575 |
Originally Posted by dan888
(Post 486576)
Ahhhh shiite Dan. That makes me want to blow chunks. Not that I've ever done that before. Good luck with it. Very sorry to hear, but looking forward to a learning experience on your dime.....:eek: ya, that was uncalled for. . . sorry |
Originally Posted by IDRIDR
(Post 486603)
Good luck with it. Very sorry to hear, but looking forward to a learning experience on your dime.....:eek:ya, that was uncalled for. sorry
Athena did write me back and say that the 09 KLX gasket kit they make, also fits the "07" bikes. ""Athena Spa wrote, in response to Dan: Dan, good news! P400250850049 fits also 2007 KLX 250 S model. Dan (unregistered) wrote: Will this fit the 2007 model KLX250s? Do you know if there are any differences between the 2007 and the 2009 engines? Thank you "" |
