Clutch shaft not engaging after lubing and reinstalling clutch cable
Old Aug 7, 2021 | 05:00 AM
cedar-leaf's Avatar
Default Clutch shaft not engaging after lubing and reinstalling clutch cable
This has happened to me before on my KLR and I managed to pull the shaft a bit up then back into position. With the KLX though I can't for the life of me figure out how to do that. Anyone got any tips?
I need the clutch shaft to go towards the red arrow. But the position it's pictured in is the furthest it would go. And yes, my lever is disconnected and the cable is loose and free on the top end with a lot of free play
Old Aug 7, 2021 | 12:43 PM
durielk's Avatar
The location of the parts in the picture matches my bike setup.
Put a big crescent wrench on that lever and see if you can rotate it towards the front of the bike. If it can be moved, nothing should be jammed inside the clutch. If this is the case, think about how you got it off and redue those steps to put it back on in reverse order.
If that lever is locked, you have something jammed and will probably need to take the cover off to see what happened.
Old Aug 7, 2021 | 03:41 PM
cedar-leaf's Avatar
@durielk It was not budging even with a cresent wrench. I drained the oil and took the cover off. The clutch arm mechanism works fine, but the button (called clutch pusher on the service manual) will not move no matter how hard I push it in.
What could it be and what do I do next?
Old Aug 7, 2021 | 04:09 PM
durielk's Avatar
OK, that Clutch Pusher is going to be very hard to move by hand, your pushing against all the clutch springs. If you had it all apart, it maybe something is not right in the clutch basket on reassembly.
Did you put new springs in?
Do you have super high mileage on the clutch basket? After a while those ears where the plates sit get wore and slotted, which would make them hang up.
Old Aug 7, 2021 | 04:22 PM
cedar-leaf's Avatar
I literally did nothing other than disconnect the clutch cable to lube it. And so far I've only taken off the cover to see what's going on behind it.
The bike has 5,000 miles on it and was running perfectly fine
Old Aug 7, 2021 | 04:30 PM
durielk's Avatar
With the cover off, will the (page 6-7, second picture) "A" clutch release shaft rotate ?
Old Aug 7, 2021 | 04:31 PM
cedar-leaf's Avatar
With the cover off, will the (page 6-7, second picture) "A" rotate?
Yes, I even pulled it out to inspect it. Made sure the washer didn't fall of too
Old Aug 7, 2021 | 05:59 PM
durielk's Avatar
OK, if it rotates, ...make sure you have the flat part looking at the clutch piston.
You did something wrong somewhere, can't believe your clutch basket is locked up when you didn't do anything to it.
Start all over and do it all again. If that don't work take it to a shop.
philgoodklx
Oct 1, 2019 11:46 AM
taxonomy
Oct 8, 2015 05:24 PM
jcbowling1985
Ninja 250R
Oct 19, 2012 05:35 PM
Sailormilan2
Feb 22, 2007 07:01 AM
Amitesh
800, 800 Classic & 800 Drifter
Dec 3, 2005 06:46 PM
