Clutch issue? Could use some advice please!
Ive browsed the forums but I finally had an issue.
I just fixed a flat front tire on my klx 250s when i realized my clutch play was all messed up. I fixed that but now whenever I hold the clutch in it seems like the gears don't disengage all the way. When I push the bike it is much harder to do so in gear with the clutch in than when I am in neutral. I feel like this isn't good but perhaps I just never noticed? I could use some advice! |
It sounds like the clutch isn't traveling as far as it should be. Visually watch the arm above the clutch cover to verify that it's fully dis-engaging when you pull the lever.
I got some vice grips and pulled the clutch farther over but that doesn't seem to help. Like I said I can push it with the clutch in but there is noticeable resistance all through the spin if its not in neutral.
re-adjust your clutch cable.....properly.
| All times are GMT. The time now is 10:31 AM. |
