Clutch cable
Old Jan 15, 2019 | 05:39 PM
philgoodklx's Avatar
Default Clutch cable
Recently purchased a 2009 UK model (fi). Has Pro-taper bars but not really high and no risers.
Bars fully turned left the clutch cable is very tight and only works on last part of pull on the lever. Fully turned to the right there's plenty of slack.
There doesn't seem to be any other route for the cable.
Any ideas would be most welcome.
Old Jan 15, 2019 | 09:21 PM
LaGrasta's Avatar
Old Jan 15, 2019 | 09:35 PM
Thanks Anthony.
I did a search under 'clutch' before posting my thread but did not come up with anything.
Will check out the throttle too now.
Old Jan 16, 2019 | 08:51 AM
ozklx351's Avatar
Instead of replacing my cable when I added risers I just got a Moose Ezi Pull. Adds 3 to 4 inches of cable length and lightens the clutch pull.
Took a few minutes to set up but has been great for a few years now.
Old Jan 16, 2019 | 09:01 AM
Thanks for that.
Any particular model of the Moose as the price seems to vary so much.
The cheapest seems to be the universal dirt bike one.
Old Jan 16, 2019 | 09:17 AM
ozklx351's Avatar
When I bought mine I just searched for klx250.
Universal may also work, but that is how I got mine.
If you get one, it is mildly fiddly to set up but having a slightly lighter pull helps on technical days.
Old Jan 16, 2019 | 09:27 AM
Thanks.
Old Jan 19, 2019 | 03:54 PM
oldgypsy's Avatar
This was my solution for a tight clutch cable: I just installed an '08 KLR650 clutch cable (p/n 54011-0556) on my '09 KLX250S. Went on quickly and easily. I had previously installed Pro-Taper handle bars, 3/4" risers and Tusk Lever Guards; which caused the clutch to disengage when turning a slow, hard left no matter how much I adjusted the OEM cable. My disengagement issues are now gone. Cost $14.17, plus shipping from No Limit Power Sports. The '08 cable is a different design (although the connects at either end of the cables are identical), but it works just as smoothly as the OEM.
Still no problems with this fix.
Old Jan 19, 2019 | 04:09 PM
Thanks.
Before I got your response I ordered a klr 300 cable which am told is 2" longer.
alky
Mar 28, 2017 06:16 PM
taxonomy
Oct 8, 2015 05:24 PM
jcbowling1985
Ninja 250R
Oct 19, 2012 05:35 PM
WhiskeyTF
Oct 13, 2011 05:36 PM
FlyBoy276
Jun 26, 2008 01:09 AM
