clucth cable frayed
Old Aug 12, 2024 | 07:01 PM
Kaw-Liga's Avatar
Default clucth cable frayed
Starting out for a ride I killed the motor because the clutch was dragging. Started to adjust the clutch cable and noticed the wire was frayed where inter the lever. I am wondering what caused it to fray.
Old Aug 13, 2024 | 02:14 AM
Olderider's Avatar
Not lubing it on a regular basis.
Old Aug 14, 2024 | 01:02 PM
And the barrel may have stuck, causing the cable to bend back and forth, eventually breaking strands. Lube the lever area and barrel of the cable as well as the cable itself.
Old Aug 14, 2024 | 01:17 PM
Kaw-Liga's Avatar
Thanks for the replies. I think the barrel was stuck. I am going to replace the cable.
Old Aug 14, 2024 | 04:19 PM
Kaw-Liga's Avatar
Actually the barrel has broken off and is stuck in the holder!
Old Aug 15, 2024 | 12:48 PM
So now you know why. When you install a new cable clean the lever or replace it, oil up the pocket. Chain lube or grease would work well. Something that will stay, not some light oil.
Old Aug 15, 2024 | 12:57 PM
Kaw-Liga's Avatar
I have ordered a new holder, barrel and lock nut. I will lube with white lithium grease or maybe silicone brake grease. Thanks for the advice!
Any other tricks for installing the new cable? The service manual is not very helpful.
Old Aug 16, 2024 | 02:48 AM
GBAUTO's Avatar
If the cable that's on it now seems to be routed properly, duplicate that with the new one.
Guard1an99
KX250 & KX250F
Aug 23, 2016 03:48 PM
jcbowling1985
Ninja 250R
Oct 19, 2012 05:35 PM
stephenmarklay
Jun 11, 2012 02:06 AM
Dallin
May 19, 2009 05:10 AM
FlyBoy276
Jun 26, 2008 01:09 AM
