carb boot install
Over 6 years ago I pulled out and reinstalled the carb, and somehow got it done without big problems, but now having a heck of a time getting the boot that runs between the airbox and the carb hooked up. Any thoughts on the best step-by-step. So far, cursing has not been a helpful step. At this point the carb is loosely hooked up to the engine. Thanks in advance. :)
Originally Posted by oldgypsy
(Post 550186)
You mention "carb boot", but then it sounds like you're talking about the manifold...part between carb and head. If so, that's odd. The part that usually starts giving trouble is the boot between the intake bell of the carb and the airbox. They actually shrink a little over time...just enough to make full fitment a little short.
On the manifold, the rubber is usually fairly robust and thick. Now, if the carb was installed for some time without the snout of the engine side of the carb fully seating into the rib in the manifold, it could be misshapen now and not allow that rib to match the rib in the carb, giving a less than stable fitment. Additionally, to insure my carb is fully seated into the manifold, I put just a light touch of mineral oil...very light... smeared into the manifold. Mineral will not harm or react with the rubber in the manifold...not much will hurt that manifold, but mineral oil is guaranteed not to...and it dissipates quickly. With some light lube I can feel that ridge in the manifold pop in and out of the ridge in the carb mouth. And no, that statement was not taken out of the dialogue of a porn video...LOL! One more thing...I use high quality stainless steel hose clamps the proper width and length to fit within the factory groove of the carb/airbox boot and the carb manifold. The clamps that usually come on most Japanese bikes are pretty flimsy. Do be aware not to overtighten, as the higher quality clamps can allow you to damage the rubber. |
Originally Posted by TNC
(Post 550193)
. Don't know that I've got any mineral oil, but I imagine a thin coating of vasoline should work. Gotta keep the porn dialogue going. The lube did the trick, thanks. :o |
| All times are GMT. The time now is 10:27 AM. |
