Can I plug my battery tender into the heater plug
Old 10-19-2011, 07:06 PM
Mcnutts's Avatar
Default Can I plug my battery tender into the heater plug
Will it work
Old 10-19-2011, 07:10 PM
Why wouldn't it? Make sure polarity is correct!
Old 10-19-2011, 07:32 PM
LikesToThump's Avatar
whats a heater plug? would polarity even matter if its AC?
Old 10-19-2011, 09:16 PM
rgoers's Avatar
I have a YUASA battery tender. The connector is un-marked as to polarity. Last night I hooked it up to charge a Gel Cell battery on my workbench. The first try, I had polarity reversed. I just touched the lead briefly... and noticed the charge LED lit RED (instead of the normal green) to alert me that I had to reverse the polarity of the lead extensions. I swapped them, and it started charging the battery. :-)
If your battery tender is as smart as my YUASA unit - it should tell you if polarity is incorrect.
Old 10-19-2011, 09:35 PM
Red usually means its charging or that it needs charging and green means its done.
Old 10-19-2011, 09:46 PM
I know charge is DC, but I simply do not know what a heater plug is...
Old 10-19-2011, 11:14 PM
Mcnutts's Avatar
Acualy I'm not sure what the plug is for that sticks out beside the seat. I assumed it was for a heated vest or something
Old 10-20-2011, 01:45 AM
o ok, now i got a much better idea about what ur saying... yea keep polarity correct and ur good, assuming the funky thing is hooked up right n such, i know my bike doesn't have a plug hanging off stock lol.
Old 10-20-2011, 02:49 AM
clgdswr's Avatar
The thing that sticks out under the seat is for a battery tender. Lucky you someone pre-wired the bike for ya.
Old 10-20-2011, 03:33 AM
Mcnutts's Avatar
So all 09's don't have that?
I got the bike with 200kms without a scratch on it in what I thought was completely stock form.
It works with my heated vest also but that kills the battery.
Quick Reply: Can I plug my battery tender into the heater plug
