Cam chain slack, timing off
Welp, got all the valves dialed back in, I think i got the tensioner dialed in, kicked back the intake cam one tooth
Started her up and I think she's worse off than before, or definitely not any better.... Wants to idle really high, if I blip the throttle will slow down a bit. Never less than 1500 even with the throttle idle cable backed alll the way out. Beyond 1.5-2 turns out, the idle fuel screw on the carb has basically no effect.
Because the carb was recently rebuilt by Bill, and because the jetting is stock from when the previous owner originally installed the kit, I'm guessing that at least one valve or valve seat is ****ed. Now to decide if I want to dig into that.......
Now that you have your valves adj, next step is to run a compression test... easier than pulling the head.
With the fuel screw not effecting the idle, I think you still have carb issues. Go to a smaller pilot jet.
I have never had an engine with a bad valve, maybe someone else here can offer advice on that, but it would seem to me if you have problems with a valve, the engine would backfire and be very difficult to start.
Hmm I'll try a compression test first. Will disable the ACR and see if i can find a leakdown tester.
As far as the fuel screw -- I'm not convinced the pilot jet is the problem. I'm using the jetting recommended by Bill for my altitude/setup, and the same jetting the previous owner used. I think it seems like the fuel screw has no effect because my idle is so ****ed anyway
The engine doesn't backfire, it isnt SUPER hard to start, but it doesn't start very easy. I have a kickstarter and I've never been able to kickstart the engine. I'm able to pop start it with a couple tries. I notice that recently almost every time i kill the engine after its been running i get a little 'burp', which i think is the ACR?
Dumb question: is it possible i installed the cams 180 or 360deg off?
The crankshaft has a T to indicate TDC, but I believe it has 2 T's per revolution right? does it matter which T i am at when i install the cams?
Ride on
Brewster
Hahaha, i guess i was thinking: if the lobes are pointed out, and i rotate the crankshaft 360d, should they still be pointed out. Sounds like the answer is NO. So i could have the camshafts installed backwards (180d) relative to a 360d rotation of the crankshaft
#28
If they were off 360 degrees, no difference. It is still right. The ignition fires every revolution, the extra spark is a "wasted spark", firing during the exhaust stroke.. That is the beauty of the single, it works regardless, so in other words you cannot be off 360 degrees. It works.
It's either jetting or bad valve in my mind, not being there to see what is going on. Turning the idle mix screw should affect the idle. That is the screw accessed just in front of the float bowl, from below.
