burnin oil!! i need to buy a cheap piston!!
anybody got a 250 piston they wanna sell for cheap? i just hit the 15k mile mark and its burnin quite a bit of oil. i want a 350 but i dont have that kind of money. thanks guys
Why not just throw a set of rings in it?
is that all it needs?
Originally Posted by 09'Kawi250s
(Post 447042)
Edit: Oh...and 15,000 miles isn't normal for a worn out piston/cylinder under any normal circumstances on this engine. Sounds like something fairly serious occurred. |
whats mic? ok thanks for the info
Unless something has critically failed, there should not be the need to replace the piston to solve an oil burning issue (esp at 15,000 miles). In my humble experience, and based on limited info, you're more likely to have a leaking valve stem seal, or worn valve guide, than a piston/ring problem.
(Post 447045)
(Post 447040)
I have a stock piston with about 1,000 miles on it. You can have it. Just pay me back for the shipping.
I would recomend replacing the valve seals while your at it. Its not to hard or expensive. I could describe my method to convert a drill press to a valve spring compressor. (Yes I should have taken pics)
