Bill Blue big bore 351
Well I finally got it all installed and running this weekend (with help)...and I must say wow. After I got it jetted properly and fixed a few small issues with my carb...it is a completely new bike! starts up immediately and after a few heat cycles took for a spin around the parking lot and I cant believe it is the same bike. I cant wait to get it out this weekend on some trails!!! :D
I will post come pics when I get all the plastic finished. Thanks to everyone that helped me and gave me tips!! |
The difference is like night and day, ain't it? When the throttle calls for more power it's there...
Just got mine installed this weekend as well. Took it for the first ride today and there is a noticable difference. Front end will come up in 1st gear ( 13 tooth front sprocket ) with just the twist of the throttle. More vibration at highway speed then when it was a 250. Also, mine starts right away, but takes almost 4 minutes before I can take it off choke and have it run by itself.
What are you doing with your plastics?
Welcome to the dark side!! :)
It's how the bike should have rolled off the Kawasaki production floor. I was riding on Saturday and met up with a few other KLX'ers. An 07, two 09's, and an 0'12. I rode the stock 07 and stock 0'12.. HOLY CRAP. How did I deal with that moped-like power?! hahahaaa |
4 minutes with choke out?...holy...that would drive the neighbors crazy...
Originally Posted by 2007 Green Machine
(Post 471709)
4 mins with choke out sounds a little much...... i can take mine off choke off after 10-20 seconds.....
Yeah four mins is a bit excessive.
I use choke for cold start and use it for about twenty seconds. After that I close it, and jump on the bike and ride away. I keep the RPM's under 4k or so for the first few mins to warm it up. Then balls out. |
only time i need to warm up the bike for a long time is if i'm starting on a downhill on a cold morning....(san francisco hills are steep)....if i don't properly warm up the bike, as it's in gear and rolling down the hill...engine will cut out...:rolleyes:
(Post 471709)
I can't see there being much of a difference between the years, but my front end cam up in the first three gears just hitting the gas. Caught me a little off guard in third lol. I have to look and see what tooth sprockets I'm using.... plastic goes back on tmrw and the next sunny say I will post pics. I was looking at some new turn signals on ebay, do I have to do anything special to upgrade them to LED? |
