Big bore kit confusion
Hi friends,
Need a big bore kit for a 2004 klx250s as ours has scored the bore,
all the ones on ebay have this compatibility below only, Was there a difference in the 2004 model in the block compared to other years? I cant find a 2004 upgrade kit anywhere.Suitable for Kawasaki
KLX300 1996-2003
Suitable for Kawasaki KLX300R 1997-2007
Suitable for Kawasaki KLX250 1993-1996
Suitable for Kawasaki KLX250R 1994-1996
Suitable for Kawasaki KLX250S 2005-2014
Suitable for Kawasaki KLX250SF 2009-2010
Cheers
KLX300 1996-2003
Cheers
I suggest you try using forum search first. You need "AHL" brand cylinder piston kit. Cylinder has "299" mark. You can get for ~$100 from Aliexpress directly from AHL - https://a.aliexpress.com/_omw07zj.
Pretty much all of the KLX250/300 since 1994 have the same cylinder/head. The main difference is that the KLX250 dual sport came out in 2006 with an electric start, where the earlier off roaders were kick start.
The AHL kit runs more like $150 to 180 usd on Amazon. It must be the 299 kit, the 292 does not fit. The kit is bolt on except for one thing. The lower cam tensioner spring cap needs to be shortened by about 4 mm, the threads on the cylinder aren't tapped deep enough. I cut and filed about 4mm off the threads and all works fine. Some comment about the AHL head gasket not lining up, but it really isn't a problem. It sticks out in the water jacket, but that likely doesn't present any problem. It just makes more turbulence in the water flow, which is good. If the water didn't get stirred up in the flow, if it was smooth laminar flow, it wouldn't cool as effectively as a turbulent flow does. Plus the water flow isn't extremely fast and high flow, so the bit of overlap into water jackets isn't really a problem.
