Barker exhaust
Old 09-18-2018, 10:56 PM
Kris250's Avatar
Default Barker exhaust
I got mine installed and it looks great! The pipe is much larger than I thought it would be should have pleanty of flow.
Old 09-29-2018, 12:49 PM
dp19's Avatar
Looks great! I just ordered one for mine. Is it obnoxiously loud? Did it make a significant power improvment?
Old 09-29-2018, 02:08 PM
Kris250's Avatar
It is loud but that’s what I wanted. Big difference but I also did no lid with K&n filter with ejk fueler all at same time.mine is fuel injected
Old 09-29-2018, 02:13 PM
dp19's Avatar
Awesome! mine is fuel injected too and I have the EJK already. Can't wait to get it lol
Old 09-29-2018, 03:36 PM
Kris250's Avatar
Don’t forget to block off pair valve. Mine has zero decel pop from 10000rpm and let off throttle
Old 09-30-2018, 11:37 AM
dp19's Avatar
Yup, already done. I have other "new" mods in the works for the EFI KLX which, if all goes as planned, I will post on here shortly. That's all I can say for now... lol
Old 10-04-2018, 04:07 AM
Kyllburg's Avatar
Does EJK show how to block block off the pair valve? Can you explain? I’m planning to buy the EJK unit, remove the lid and change the exhaust. Is the Barker exhaust a slip on, or does that also replace the pipe/header?
Old 10-04-2018, 01:34 PM
dp19's Avatar
There are several ways to block off the pair valve. You can cut the hose (or buy a new 1/2 inch hose) and plug both ends with a PEX 1/2 inch plug and clamp (used for plastic house plumbing). Some use silicone to block it off. Bill Blue also sells a block-off plate with his big bore kit that will bolt to the head and he also sells the Barker exhaust. You can probably buy just the plate (and exhaust) from him. I don't think the EJK includes anything to do this (mine didn't).
Old 10-04-2018, 01:46 PM
dp19's Avatar
kevinkromka
05-21-2022 04:46 PM
kgwld1
03-18-2019 10:21 PM
Kris250
12-29-2018 06:15 PM
pie4foou
02-10-2008 09:04 PM
mugwump
Ninja 500R
03-23-2007 12:17 AM
Quick Reply: Barker exhaust
