-   -   Barkbusters Handguard Instalation probleme cause of stock handlebar (https://www.kawasakiforums.com/forum/klx-250s-71/barkbusters-handguard-instalation-probleme-cause-stock-handlebar-40271/)
Yson May 17, 2013 12:02 AM
Lets get to the point, i bought these nice handguards :
Barkbusters VPS Handguard for 7/8
I also bought the supermoto sliders to go with em and the endbars weight for looks.
I tried installing em tonight on Stock handlebars.. OOPS no go ..
Theres an insert inside the stock klx250s 2012 and so I cant bolt these on unless I remove this insert and so my question is... is it possible to remove it ? It seems like there's 3 welds on the outside, if I buff em off will the insert come out ?
Or do I have to just buy a nice new handlebar with grips.. ? Oh and ya.. what is the easiest way to remove the handgrip on the clutch side.. ?
Thanx
Ps: my english aint so great because i'm french .. sorry folks :p
RaceGass May 17, 2013 12:19 AM
Air pressure will remove the left grip.
Some have trimmed the bars right after that welded in piece in the stock bars. Better to replace the bars with a new pair,stock bars bend if you look at them wrong!
Brieninsac May 17, 2013 05:01 AM
This has been talked about quite a bit in other threads. I've heard a few different methods, one that comes to mind is using a Dremel on the welds.
RockabillSlapMatt May 17, 2013 05:56 AM
I just tapped it
795.0pacecar May 17, 2013 08:25 AM
I ground the welds down and blew the plugs out with compressed air.
zippets May 17, 2013 10:31 AM
i ground the welds off (they are just tacked on)
then i drove a wood screw in the end and pulled it out with a hammer
worked like a charm :)
klx4me May 17, 2013 01:12 PM
1 Attachment(s)
Before undertaking this task and purchasing Barkbusters, you should have referred to their catalouge or done a search on this forum as suggested by Brieninsac...
"Avant d'entreprendre cette tâche et l'achat Barkbusters, vous devriez avoir évoqué leur catalouge ou faire une recherche sur ce forum comme suggéré par Brieninsac ..."
