-   -   B&B off road frame protectors have arrived! Wow! (https://www.kawasakiforums.com/forum/klx-250s-71/b-b-off-road-frame-protectors-have-arrived-wow-45319/)
s10gto Dec 28, 2017 12:10 PM
Just a Fyi if anyone is looking for some well built frame guards. I wanted ones that would provide protection from my entire boot and prevent boot hang ups. B&B Off road was the answer. Very nice aluminum with padding on rear and only about 2 weeks shipping time. I will add a pic when I get them installed.
Thanks B&B!
https://cimg3.ibsrv.net/gimg/www.kaw...cd784fce57.jpg
https://cimg5.ibsrv.net/gimg/www.kaw...74777fedec.jpg
s10gto Dec 28, 2017 01:31 PM
Needed a little trim for the right side pass peg ,but overall very pleased with them.https://cimg2.ibsrv.net/gimg/www.kaw...7eff3d0a57.jpg
https://cimg7.ibsrv.net/gimg/www.kaw...072a4791c2.jpg
ozklx351 Dec 29, 2017 08:58 AM
Mine are holding up great more than 12 months on.
I have contacted them before about engine case guards but no luck. They told me that there would not be a big enough market for them to make them.
I'd like to band together and inundate them with emails. Might work.
Why doesn't anyone make case guards for these little bad boys?
klx678 Dec 29, 2017 10:40 AM
When you say case guards, are you talking about something that substitutes for the bash plates?
Something ear like?
https://cimg4.ibsrv.net/gimg/www.kaw...54688b4137.png
small loops? If so you may be able to make them from some bent steel tubing (like a pair of steel handlebars) since it looks like this for the 650, a set of half loops
https://cimg2.ibsrv.net/gimg/www.kaw...7b2b3c002b.jpg
There are more elaborate ones made for the 650, didn't find any for the 300, but if you have a buddy who can weld or can at least tack weld you could fabricate a set and have a shop do a pro job of welding. One possibility to do fabrication if you have some creative skills - use some PVC water pipe and heat to bend the general shape, then have tubing bent up to match. My brother did that when he was making a hard tail for a street tracker, building with plastic before having done in metal.
ozklx351 Dec 29, 2017 10:55 AM
No, more like these bad boys.
https://bboffroad.com.au/case-guard-suzuki-drz400-pair.html
s10gto Dec 30, 2017 01:05 AM
Case guards would be sweet. I'd buy them!
outrecording Dec 30, 2017 05:43 AM
Without a doubt, I would buy case guards. Every time I go down on the left side, I worry my (longer) shift lever will crack the case.
ozklx351 Dec 30, 2017 05:53 AM
It is something I would greatly like to have. We need to get as many people on board and send b&b a crap load of requests in a short period of time. If they can see it is financially viable to produce I'm sure they would.
Other than desperately needing to fix my suspension, this is one of the few mods I have left that I really want.
klx678 Dec 30, 2017 11:58 AM
You can weld a small plate on the back side of the brake lever (right hand shift) to make a pad that will spread the load over a wider area. Riders used to do that on the old big Brit twins and singles and some Euro bikes in the 60s-70s. That will stop from punching a hole in the ignition case. Works until someone makes those kinds of covers.
s10gto Dec 30, 2017 12:08 PM
Hey Oz assuming your in Australia maybe you could give them a call and ask how many orders would it take? Looks like we got three so far.
Come on fellow Klxer' s lets get a group interest going.
Just a thought but worth a try.
