modded my KLX, now intermittent power
Old 06-12-2018, 07:19 PM
justinf's Avatar
Default modded my KLX, now intermittent power
Hey guys, I recently upgraded my 2012 KLX250 with the Bill Blue 351 kit and pumper carb, an FMF Q4 slip on, and an IMS replacement gas tank. My auto mechanic did the work and he's generally quite good but not truly a bike guy (and my Ducati guy wouldn't do it, lol). Everything is cool except I am getting some intermittent power transfer when I give it a good bit of throttle, up around 7k rpm or so. I went (painfully) through the warm-up period for the cylinder kit, so that's not an issue. Any thoughts on what might be causing this? Thanks.
Old 06-12-2018, 08:34 PM
RageHardIntoTheBendies's Avatar
Probably jetted to lean, whats your plug look like?
Old 06-12-2018, 09:34 PM
justinf's Avatar
I'll check it...what would indicated jetted too lean? Thanks!
Old 06-12-2018, 09:49 PM
Assuming you are using non ethanol blended gas (blended gas makes it harder to read the plugs)
On a Very basic level your looking at the color of the plug’s porcelain tip. A white colored plug shows a lean mixture, a dark plug shows is rich. A light brown/cardboard color is optimal.
Best way to check is to throw a fresh plug in and do some plug chops. A plug chop is basically riding the bike at a specific throttle opening (full, 3/4, 1/2, 1/4, idle), hit the kill switch while riding, pull in clutch and quickly pull over to remove the plug and check color.
There is actually lots of info to be gained by reading plugs.
NGK Spark Plugs
Old 06-12-2018, 09:53 PM
justinf's Avatar
Excellent, I'll check it out. Thank you!
explorer21
07-24-2013 12:21 PM
Feral Donkey
07-29-2010 04:08 PM
je2000
12-16-2008 09:49 PM
FM_Thumper
08-03-2008 05:54 AM
Thunderchild
12-14-2006 06:15 PM
Quick Reply: modded my KLX, now intermittent power
