antifreeze change/
Old Aug 15, 2015 | 10:05 PM
KLX25O's Avatar
Default antifreeze change/
changed the antifreeze today using Peak 50/50 pre-diluted antifreeze.
On the bottle Peak does not say its silicate free , but on there website it states it is indeed silicate free. The jug even says safe for aluminum radiators and motorcycles of all kinds. Got the jug from Advance Auto along with a $5 rebate.
Flushed the radiator with a mix of white vinegar and distilled water. Used a water measure and it took about 6 cups to fill the radiator.
The drain is located on the bottom of the water pump. I used the tools that came with the bike to remove the drain.
Also there is a screw holding the radiator cap on, and all of the radiator fluid will come out the drain with the cap removed.
Started the bike to let the block get warm to the touch before draining.
I didn't notice and rust or anything draining from the radiator.
The only dirt I found was in the overflow tank, which I removed with distilled water, with the overflows drain hose removed.
Keep in mind the white vinegar/distilled water mix is also a 1:1 or 50/50 mix, example 2 cups white vinegar 2 cups distilled water.
Old Aug 16, 2015 | 01:34 AM
You got my curiosity up on the radiator cap being retained by a screw. Mine just unscrews until you line up the tangs on the cap and rad neck. Is there something different on other models?
Yeah, not unusual for a little debris in the overflow tank. Good for you. A lot of people neglect the cooling system.
Old Aug 16, 2015 | 02:03 AM
KLX25O's Avatar
Default radiator cap
Yea I kept trying to get the radiator cap off and it wouldn't turn!
There is a screw that goes through the cap and catches the "tang" on the radiator.
2012 model KLX250s.
LordVngr
Nov 17, 2006 09:35 PM
PALYDIN11
Oct 25, 2006 08:11 AM
dedbrok
Aug 11, 2006 03:15 AM
Cold Iron
Jul 24, 2006 09:47 PM
ZX12Rider
Feb 3, 2005 03:54 PM
