Another Newbie Question
Old May 23, 2013 | 02:34 AM
zippets's Avatar
the klx stock is to lean as rocky said JET IT
Old May 23, 2013 | 10:00 AM
linkin5's Avatar
I've not seen a lean afr on an 09 or up stock bike, most were more rich than lean that is why it responds so well to the slip-on alone. I'd add the slip-on and see, if you have issues jet but on my 09 it wasn't necessary at all and when I did open the airbox and jet it made less of a difference powerwise than the slip-on alone.
Old May 23, 2013 | 10:29 AM
zippets's Avatar
i dont know about that mine i bought brand new and the first day it turned the header a very deep purple to me that says LEAN
Old May 23, 2013 | 10:45 AM
zl PINHEAD lz's Avatar
That's good to know... Thanks
Old May 23, 2013 | 02:50 PM
RockabillSlapMatt's Avatar
Don't just look for one excuse not to jet. You will benefit from jetting more than the slip-on. Even more so with the air box lid removed or an aftermarket snorkel. There's no way around it. It depends on your elevation of course.
Old May 23, 2013 | 03:27 PM
RaceGass's Avatar
Remember your location has everything to do with it. In so cal I had a 40 pilot jet before going with a fcr35. Higher altitudes may not need rejetting. Sea level here required it as the very first ride the header was turning blue from the heat.
Old May 23, 2013 | 03:43 PM
linkin, I wouldn't necessarily dispute what the AFR readings might be on the OEM needle, but I doubt there's little debate about the lousy profile of that OEM needle. This is where the DJ needle kills in terms of great response and performance. The OEM needle yields a funky, herky-jerky throttle response even when you lift it with washers. It also has a sensitivity to surging when trying to maintain a steady cruise throttle position. It's not unrideable, just not optimum.
Old May 31, 2013 | 12:17 PM
So my exhaust came and looks well apart from one thing...
It has no bung for the O2 sensor unlike the stock pipe.
If I was to replace the old exhaust with the new, what would need to be done with the O2 sensor?
Thanks guys
Old May 31, 2013 | 01:38 PM
cmott426's Avatar
Your bike is fuel injected.....??
Old May 31, 2013 | 02:27 PM
It is..
