AMPs consumption when ignition OFF
Old Mar 19, 2015 | 05:20 PM
SpongeBob's Avatar
Default AMPs consumption when ignition OFF
Hello,
I want to ask how many mA of current does electrical system burn when the ignition is off.
Thanks for the answers
Old Mar 19, 2015 | 07:04 PM
SpongeBob's Avatar
I just made a measuring and if I stop the engine and turn the ignition off and measure using ampermeter the current it will show about 20 mA. If I consider that the battery has 7 Amper hours. Therefore by this consumtion it means that battery will be drained out by 7/0,020 hours which is 14,5 days. Something is wrong. Does the draining current decrease after some period of time?
This is my question.
Thanks
Old Mar 19, 2015 | 10:20 PM
durielk's Avatar
Where is it draining too?
Are you sure your amp probe is calibrated at that draw?
Old Mar 19, 2015 | 10:46 PM
ol'klx-er's Avatar
The '09s and newer will have some draw due to the digital dash.
Old Mar 20, 2015 | 01:38 AM
marcham's Avatar
What is the accuracy of your multimeter? Do you have problems with the bike sitting?
Old Mar 20, 2015 | 06:55 AM
Duomike's Avatar
Interesting. Acc. to the manual the battery can go flat in a couple of days even with ignition off. For sure the digital dash sucks some current. In August I'll go home for 2 1/2 month and I surely will disconnect the battery
Old Mar 20, 2015 | 07:00 AM
SpongeBob's Avatar
I did not read the value from the multimeter correctly I was confused how small current it is.
That means that the 0.0002A current can drain the battery by 874 days to its 40%
That means that the battery self discharging is much bigger than the discharging by the electronic ECU
That is good information
rebl617
Sep 19, 2013 03:31 AM
jhoffy22
Jul 25, 2011 05:15 AM
BigDSS
Jul 2, 2008 12:04 AM
zzone
Aug 29, 2006 09:34 PM
incabiker
Apr 25, 2006 04:50 AM
