Air screw
Old Feb 8, 2010 | 06:49 PM
scallen's Avatar
Default Air screw
I have a 2009 klx250s. Has anyone only adjusted the fuel screw and if so what results were obtained.
Old Feb 9, 2010 | 01:30 AM
WestOzKLX's Avatar
You'll need to remove the carb' to access the screw (remove plug.) While you're at it fit a Dynojet #2206 kit. Job done.
Old Feb 9, 2010 | 01:35 AM
Tmoe's Avatar
+1 Oz! If your goin into the carb, you might as well go ahead and re-jet.
Old Feb 9, 2010 | 01:53 AM
lcpl0331's Avatar
Your only fatten'en up the mix just off idle by adjusting your fuel screw. If your not re-jetting the carb and don't have any decel popping then don't waste your time messin with it.
Old Feb 9, 2010 | 06:11 AM
cjcrashesalot's Avatar
You might as well get an adjustable T handle fuel screw while you're at it, in case you don't get it perfect the first try.
Old Feb 9, 2010 | 12:38 PM
scallen's Avatar
I have hesitation at about 3,000 rpm's especially when cold. Plan on doing the rejet and kouba screw and a slip on hopefully in the near future. I just thought that I might be able to get rid of the hesitation. I just wish theses carbs were easier to get to. My old 81 KDX250 was a breeze. Kinda wish I had that motor in this frame.
LordVngr
Sep 16, 2006 03:49 AM
cwgoff
Aug 28, 2006 09:53 PM
krntl13
Jul 23, 2006 02:58 AM
mario66
Jul 12, 2006 06:44 PM
ZX_9r
May 13, 2006 06:46 PM
