Aftermarket key/ignition or stock ignition remount?
Old Jul 25, 2011 | 04:15 AM
jhoffy22's Avatar
Default Aftermarket key/ignition or stock ignition remount?
I've been searching the forums, but haven't really found anything sufficient yet. I will be properly installing the Vapor and the X2 headlight and I've noticed that I am going to have to remove the current key/ignition. I would be satisfied with remounting the stock ignition but would like to hear of any ideas/suggestions that you guys may have. I would like some sense of security and not just having a toggle on/off switch.
Old Jul 25, 2011 | 04:59 AM
RaceGass's Avatar
Here's something to think about, might even work with the stock ignition key location.
https://www.enduroeng.com/CategoryPr...duro+Equipment
Looks like it mounts off the bar mounts maybe?
Old Jul 25, 2011 | 05:15 AM
jhoffy22's Avatar
I would be fine with using that but I would still have to remove the ignition because the X2 light won't fit with it in place even without a speedometer in between there.
jhoffy22
Nov 19, 2021 06:33 PM
jvessels
Oct 29, 2011 02:45 AM
kabbage
Jul 13, 2009 05:48 PM
aszrael1266
Dec 4, 2007 04:05 AM
jadasimone
Ninja 250R
Jun 15, 2007 02:04 PM
