Adding Bark busters to Stock Bars
Old Dec 24, 2008 | 04:09 AM
horizonod's Avatar
Default Adding Bark busters to Stock Bars
Sounds simple enough but I can't get the slip collar into the bar ends.
I tried drilling and once I get through the rubber I hit metal. I can stick a screwdriver up the end several inches but a half inch drill bit doesn't want to go and I don't want to push it.
Is there a trick???
Old Dec 24, 2008 | 04:37 AM
redpillar's Avatar
The stock bars have weights in the ends. You can tap the holes in the weights to 1/4 inch thread.
Old Dec 24, 2008 | 04:41 AM
cliffsta's Avatar
What redpillar said. Tap the holes and use the bolts:
Old Dec 24, 2008 | 05:08 AM
horizonod's Avatar
OK. Thanks. Anything special to do on the throttle side or and other mods while there? Add washers, spacers, bushings, cup holder, ash tray, tassles......oooooooooo tassles!!!......PINK tassles!!.....
Old Dec 24, 2008 | 11:45 AM
Flood_33's Avatar
I would go over to www.rockymoutainatvmc.com and pick me out a set of tusk cR high bends, then install that and my new bark busters together. The stock handle bars are steel and have a 1970's bend. The Tusk bars are lightweight and feel so much better than stock, plus i think you can ****** you up a pair for 30 american dollars.
Merry Christmas,
Flood
Old Dec 24, 2008 | 12:29 PM
TomN's Avatar
I had the same problem, I got new bars after I messed up tapping them, KX high which were not quight high enough.
Old Dec 24, 2008 | 03:15 PM
horizonod's Avatar
I've got a set of used renthal bars that needs to be cleaned up. I'm looking for a reason to swap them out anyway. If I screw up the tapping, which I already might have,.....there's my excuse!
Old Dec 24, 2008 | 08:06 PM
kawiridr05's Avatar
i had alot of trouble out of mine also. they didnt line up right to the bar so it was pretty tough. let's just say i threw some glue on there and used a few other cheap tricks, but they're on now
Old Dec 25, 2008 | 02:16 PM
oldphart's Avatar
Banned
Default bark busters
Go with your Renthals, those stock bars are really heavy and bend and break easily. I got a set of Tusk cr high bends and am happy with them.
Old Dec 25, 2008 | 04:18 PM
I drilled mine out with a 5/8 drill bit. Then a dremel to clean up the welds. But tapping it sounds a lot easier.
