Acerbis tank and stock Kawasaki fuel valve petcock??
Is anyone using the stock Kawasaki vacuum fuel valve petcock in conjunction with an Acerbis 3.7 tank??
I have forgotten to shut off the Acerbis manual fuel valve twice in the last month and filled the bottom end with gas. Not good!!! I had to drain the oil and change filter. This is the only bike I own that I must shut off the fuel valve all the rest of the bikes have vacuum operated valves. This is something that I am just not used to and I really don't want to have to shut the fuel off every time. Plus it's a pain in the ass getting to the Acerbis fuel valve to shut it off. I have been thinking about rigging up my old stock Kawasaki fuel valve somewhere inline between the Acerbis fuel valve and the carb. Any suggestions?? Thanks!! |
I seem to recall someone trying the stock petcock on the Acerbis tank. It may have been redpillar.
Sounds like you have a problem with the carb needle & seat and/or float level. It shouldn't flow like that. Time to pull the carb for a cleaning & inspection. |
Originally Posted by IDRIDR
(Post 525008)
Sounds like you have a problem with the carb needle & seat and/or float level. It shouldn't flow like that. Time to pull the carb for a cleaning & inspection. I still would like a vaccum valve tho. :) |
Both the 2009 and 2011 KLX250s I own (owned) had manual fuel petcocks, not vacuum operated. If you're flooding the cylinder with fuel then, as mentioned, you likely have a sticking float needle. Float height, I'd think, would have to be drastically off to be the culprit, but I guess could be possible.
Originally Posted by rgmr250
(Post 525011)
My 2006 KLX did not come stock with the vacuum actuated petcock. My 2006 KLR650 does.
